Need help with Steeda sport springs
Old Mar 23, 2012 | 07:16 PM
ZackeryJc's Avatar
i installed the Steeda sport springs and Steeda pro action shocks and struts last weekend and i have double checked my work and so has my friend and everything looks like its installed correct but when i am driving it and hit an bump or on a rough road i am hearing a clunking sound coming from the back pass side.. we are thinking it mite be the bumper stops but not 100% sure so i am asking yall.. its a 2011 5.0 so any input would help thanks
Old Mar 24, 2012 | 01:58 PM
Nocturnal'14's Avatar
Try checking the sway bar against the axle back pipes! Happened to me on my wife's car! It was hitting ever so slightly but would make a large thump sound like something was loose. It's fixed now though!
Old Mar 24, 2012 | 04:24 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
Old Mar 24, 2012 | 05:17 PM
PureSpeedMotorsports's Avatar
+2 we've encountered this very thing on a few customer cars.
Old Mar 25, 2012 | 11:26 AM
ZackeryJc's Avatar
Me and my buddy was looking all round so we took everything apart and the top of the spring.. The paint is wore out like it has been rubbing hard.. So I parked upward on a hill and look likes the stops and they where bottomed out so I think I am going to cut them and see if that's the problem
Old Mar 31, 2012 | 03:36 PM
ZackeryJc's Avatar
Okay so I cut my bumper stops and that wasn't the problem.. Going to lift it again tomorrow and see if my exhaust is hitting my axle or see if my Panhard bar is tighten good
Old Mar 31, 2012 | 03:50 PM
11SHELBYGT500's Avatar
Did you mess with the rear sway bar?
Old Apr 1, 2012 | 09:13 AM
ZackeryJc's Avatar
The sway bar wasn't the problems i think... I took out the frame bar right above the Panhard bar and I don't hear no clanking but I dont know how safe it is without it in since it was connected to the frame
Attached Thumbnails Need help with Steeda sport springs-image-4090427662.jpg
Old Apr 2, 2012 | 05:44 AM
Long Stroke's Avatar
You need that support brace in your car. It helps support the panhard bar's mounting location.
I would check your exhaust clearance, it sounds like that might be hitting the support brace.
Old Apr 2, 2012 | 11:26 AM
ZackeryJc's Avatar
It's hitting that support brace.. When it was in there was a gap of about 1/4 between the brace and the exhaust.. Other than removing the brace I don't see a option on fixing it.. And other options would help me out?
Old Apr 2, 2012 | 04:15 PM
2012GTCS's Avatar
I dont think a lot of guys are experiencing this issue. The should install with everything else remaining in place.
Old Apr 2, 2012 | 04:46 PM
ZackeryJc's Avatar
I know, I called Steeda and they told me it could be the bumper stop so I trimmed them, told me the axle can be hitting the exhaust so I looked and that brace was 1/4 away from frame so I took it off and I don't hear the clanking noise anymore so that has to be the issue but I think it has to be there but can't figure out what else to do without it rubbing on the frame everytime I hit a bump lol
Old Apr 2, 2012 | 06:54 PM
tj@steeda's Avatar
Hello Zack ,
Here is what Gus thinks:
Springs don't make noise unless they were installed without the spring isolators which gives you metal to metal contact, then it would be a creak, not a clunk.
A clunk means something is hitting, his exhaust is a good culprit. The axle could be hitting one of the tailpipes through suspension travel. If he took out the panhard bar brace like he describes and the sound went away, exhaust routes right by the panhard bar brace. Sounds like the clunk might have been his exhaust hitting the brace.
You have to understand it is hard for us to diagnose something like this due to what your describing, unless we were looking right at we could make a definate diagnosis, but based on what you are saying this is our best observation.
Let us know if this could be the issue.
Best Regards,
TJ
Old Apr 2, 2012 | 07:33 PM
ZackeryJc's Avatar
Originally Posted by tj@steeda
Hello Zack ,
Best Regards,
TJ
Yes that is the issue TJ, the brace is hitting the exhaust when I hit an bump.. Any way I can fix this?
Old Apr 3, 2012 | 02:32 PM
ZackeryJc's Avatar
Well I called and talked to steeda and they said I have to loosen all the exhaust from the h pipe and work it down to I can fix the problem
Old Apr 3, 2012 | 06:31 PM
ZackeryJc's Avatar
Fixed! Finally lol
Old Apr 4, 2012 | 08:37 AM
2012GTCS's Avatar
Nice! So just some exhaust adjustment?
Old Apr 4, 2012 | 09:07 AM
ZackeryJc's Avatar
Yep, and I adjusted my Panhard bar also..
Old Apr 5, 2012 | 10:16 AM
tj@steeda's Avatar
Glad to hear it worked out for you. Sorry I wasn't able to respond sooner I have been on the road.
Hope you enjoy the "rattle free" Mustang!
Best Regards,
Tj
Old Apr 5, 2012 | 01:20 PM
ZackeryJc's Avatar
Best Regards,
Tj
Oh I do.. Thanks for y'alls help
