Need help: 275/35/19 or 275/40/19?
Old Sep 2, 2013 | 11:09 AM
2011 GT's Avatar
Question Need help: 275/35/19 or 275/40/19?
I am in need of new tires again for my 2011 GT with Brembo Brake option. I would like to go just a little wider from the stock 255/40/19's and would like to go with 275's all around.
However, the big question is, 275/35/19's or 275/40/19's?
Price is not much different, but I was more concerned about fitment/rubbing. I am running the Steeda Ultralite lowering springs with the Ford Racing Black Track Wheels (identical to the Brembo wheels) on my car.
Looking at a tire comparison calculator, it appears that the 275/35/19's are 0.4 in. smaller in diameter, whereas the 275/40/19's are 0.7 in. larger in diameter, compared to the stock 255's.
Any experience, suggestions and recommendations are greatly appreciated.
BTW: I am currently running the General G-Max, which in my opinion is an excellent all-around tire, especially for daily driving. I was really happy with it...
Old Sep 2, 2013 | 12:04 PM
Moustang's Avatar
Without measuring your tire clearance I would suggest the 35 rather than the 40 sidewall. With your car already lowered increasing the tire diameter could cause rubbing issues. The slightly smaller diameter of the 35 shouldn't make any significant difference in the way the car performs and eliminates the concern about rubbing.
However, if you've got the extra 3/8ths inch of clearance for the tire with the suspension compressed and you aren't tracking the car then go for the 40s. They will give you an even more lowered appearance and a bit better ride comfort than the 35s.
Old Sep 3, 2013 | 10:03 AM
linelock's Avatar
If they fit with your springs, which they probably do, I would get the 275/40. They just fill out the wheel well much more. The stock 255/40-19 already look small in the wheel well. I couldn't see going to a smaller diameter myself.
Old Sep 3, 2013 | 07:30 PM
2011 GT's Avatar
Thanks guy, I greatly appreciate the input. Without cracking out the tape measure, and by just taking a quick look at it, it appears that there is plenty of room all around the tire to accommodate the extra 0.7 in diameter, even with the wheels locked fully to either side.
Is there anyone out there currently running 275/40/19's all around with any kind of lowering springs?
Thanks again...
Old Sep 8, 2013 | 10:16 AM
M3hunter's Avatar
Thumbs up
Check also the page at Discount tire, and the recommend upgrade with the Brembo wheels (9x19) on all four wheels are:
265/40R19 or 275/40R19
I went with 275/40R19
Old Feb 21, 2018 | 02:36 PM
Joseph Stephen's Avatar
Anyone have a picture of a square setup of 275/40/19 on the stock Brembo wheel 9inch wide. Thinking about a square setup for my next one from michilen. Thank you
Old Feb 21, 2018 | 06:19 PM
5.M0NSTER's Avatar
Not quite what you asked for, but here are some 275/35-19 pics on SVE 19X9.5 drifts, and 275/40-19 on the same rim.. It can work on stock rims if you don't plan to do any performance oriented driving. If you do that wheel is too narrow.
Attached Thumbnails Need help: 275/35/19 or 275/40/19?-img_0389.jpg   Need help: 275/35/19 or 275/40/19?-img_0851.jpg
Old Feb 24, 2018 | 03:28 AM
Siber Express's Avatar
Not Brembo's but the same width tires and offset is close
Old Feb 24, 2018 | 12:39 PM
EF1's Avatar
EF1
See if this helps.
275/40-19" Bridgestone Potenza S04 Pole Positions on stock Brembo wheels
Attached Thumbnails Need help: 275/35/19 or 275/40/19?-ef1.jpg
Old Mar 4, 2018 | 12:07 PM
Ponywars's Avatar
any negative at all going from 255 to 275 square EFI?
Old Mar 4, 2018 | 01:25 PM
EF1's Avatar
EF1
No negatives on the street, but some at the track. The stock brembo wheels are only 9" wide which is the narrowest wheel that most tire manufacturers suggest on 275 wide tires. I am starting to get some sidewall roll and excessive wear on the outside shoulders at the track. I am going to a 10" wide wheel for my 275's for the track and will probably go back to a 255 40 19 on my stock wheels for the street.
Old Mar 4, 2018 | 02:16 PM
duff's Avatar
.. the big question is, 275/35/19's or 275/40/19's?... concerned about fitment/rubbing. I am running the Steeda Ultralite lowering springs with the Ford Racing Black Track Wheels (identical to the Brembo wheels) on my car. Any experience, suggestions and recommendations are greatly appreciated ..
I've run both, on 10 wide wheels (boss LS style), with vogtland springs which are nearly the same as ultralights. No rubbing, sumi htrz. I like the 40s are better for ride and steering, 35s look better (less chunky) on the wheels imo.
Old Apr 23, 2018 | 10:45 PM
759Rider's Avatar
My Brembo is on 275/40-19 on stock 9" wheels. Lowered on P springs and GT500 hats
I am putting together set of track wheels and will go with the same tire size on 10" wheels.
One alternative is an 18" wheel of the same size as well. I am a big fan of square on these cars.
Old May 1, 2018 | 07:45 PM
EF1's Avatar
EF1
I prefer the square set up as well. It handles well and I can still rotate to maximize tire life. If I was into drag racing I would probably stagger to maximize straight line traction.
Old Jul 31, 2018 | 11:45 AM
Mike Pajewski's Avatar
Talking
275-40-19 Sumitomo HTR ZIII's on 19 X 9.5 SVE Drifts. They ride a little harder than the original Pirelli Track Pack tires but the improved handling grip on track days was amazing. I've gotten about 20K on them. I am replacing them with Continental Extreme Contatc Sports.
Attached Thumbnails Need help: 275/35/19 or 275/40/19?-ms8_1553.jpg
Kestral
Sep 5, 2015 11:50 PM
2011 GT
30
Feb 2, 2014 01:52 AM
StangRalle
13
Nov 14, 2006 12:26 PM
