Lower Control Arm Heat Shield Install
Decided to try and tackle the heat shields mentioned in this TSB
before I got any squeak.
http://luxjo.supermotors.net/MUSTANG...B%2013-9-3.pdf
They are alum, and I've done some TIG, but very little alum
and nothing this thin. So I made some bolted on brackets.
Nothing high tech, but they fit up nice, are removable (pretty
tight fit in and out), and do not vibrate audibly up through 90.
Some pics
Large nuts are SS 14-2.00 jam nuts. I used blue loctite on them.
Could only find them @ Sears hardware.
Small screws/nuts are #10 SS, used red loctite.
Brackets are 2 X 1/8 and 1 X 1/8 stock respectively.
I traced edge of each bracket to give you basic idea of shape.
http://luxjo.supermotors.net/MUSTANG...20BRACKETS.pdf
Cost was
Brackets- $9.33 each
2 X 1/8 X 3 ft alum bar -$10.00
1 X 1/8 X 4 ft Alum bar - $8.77
14-2 SS nuts- $1.74 each
#10's had lying around
Also made a drawing with bracket dimensions I have yet to scan yet,
will get that up soon.
Some pics
Cost was
Added bracket diagrams with dimensions.
http://luxjo.supermotors.net/MUSTANG...DIMENSIONS.jpg
I was able to install these with no problems. The drawings were spot on. The only change I made was to the brackets to a thinner material as it made it a little easier to bend. They were still plenty strong enough to support the shields. This is definitely a worth while mod.
SMBJoshy
8/16/15 02:48 PM
Big-D
7/27/15 11:24 AM
