Lower Control Arm Heat Shield Install
Old Sep 15, 2014 | 07:08 AM
OX1's Avatar
OX1
Decided to try and tackle the heat shields mentioned in this TSB
before I got any squeak.
http://luxjo.supermotors.net/MUSTANG...B%2013-9-3.pdf
They are alum, and I've done some TIG, but very little alum
and nothing this thin. So I made some bolted on brackets.
Nothing high tech, but they fit up nice, are removable (pretty
tight fit in and out), and do not vibrate audibly up through 90.
Some pics
Large nuts are SS 14-2.00 jam nuts. I used blue loctite on them.
Could only find them @ Sears hardware.
Small screws/nuts are #10 SS, used red loctite.
Brackets are 2 X 1/8 and 1 X 1/8 stock respectively.
I traced edge of each bracket to give you basic idea of shape.
http://luxjo.supermotors.net/MUSTANG...20BRACKETS.pdf
Cost was
Brackets- $9.33 each
2 X 1/8 X 3 ft alum bar -$10.00
1 X 1/8 X 4 ft Alum bar - $8.77
14-2 SS nuts- $1.74 each
#10's had lying around
Also made a drawing with bracket dimensions I have yet to scan yet,
will get that up soon.
Old Sep 15, 2014 | 07:23 AM
dusman59's Avatar
This is a superb write up. Anytime I can avoid taking my car to the dealer I'm all in.
Old Sep 15, 2014 | 11:35 AM
OX1's Avatar
OX1
Thanks, I agree. Even if it does not happen during warantee, what about 80K miles from now after 6 -7 summers.
Added bracket diagrams with dimensions.
http://luxjo.supermotors.net/MUSTANG...DIMENSIONS.jpg
Old Sep 22, 2014 | 08:26 PM
88lx50's Avatar
That's a great job you did. I wonder how effective those pieces will be with that giant cat sitting right on top of it though. I might add these anyway.
Old Oct 8, 2014 | 08:46 AM
dusman59's Avatar
I was able to install these with no problems. The drawings were spot on. The only change I made was to the brackets to a thinner material as it made it a little easier to bend. They were still plenty strong enough to support the shields. This is definitely a worth while mod.
SpeedyJoe
18
Aug 23, 2015 02:42 PM
SMBJoshy
Aug 16, 2015 02:48 PM
Big-D
Jul 27, 2015 11:24 AM
killaz05
Jul 24, 2015 08:49 AM
