J&M Adjustable Caster Camber Plates
Currently a Corvette Owner!
Anyone using J&M Adjustable Caster Camber Plates? I have a 2011 GT. My speed shop says I really need CC plates now. Did not originally - I've gone four years without CC plates. I have Eibach Pro System Plus Kit (springs, dampers, sways). But original strut mounts are weak now, and alignment without the CC plates is now very cumbersome (read...' more expensive'). So it looks like I have to get CC plates, and I like what I read about the J&M set...especially that they completely replace the OEM strut mounts. Any reviews/feedback from 2011-2014 owners?
No experience here with J&M, but I remember reading some complaints about noise at low speeds and over bumps. This is why I went with Steeda units, they guarantee no increase in NVH which I'm sensitive to.
LEXiiON
Yes, couldn't agree with them more!
The factory strut mounts are prone to developing a creaking and popping when used with performance springs.
Our sealed bearing design eliminates that plus our is adjustable for camber, so you can set your camber for street or track use.
You can check them out here: http://www.steeda.com/steeda-mustang...unts-555-8135/
Happy to help you with a set ... you can email me at tim@steeda.com.
Best Regards,
TJ
Best Regards,
TJ
Thanks, everyone. My car is so noisy over slow bumps now, I could not bear buying/installing the J&Ms and not curing that! So you saved me, thank you. TJ, I will e-mail you.
![Grouphug](https://themustangsource.com/forums/images/smilies/grouphug.gif)
Eventually I had to go with true camber/caster plates because the BMR A-arms pushed the caster out of spec. Maximum motorsports makes an excellent set, for about the same money as the Steeda HD mounts, and same great quality. Just a little more difficulty to install.
BTW, I still have my Steeda mounts, only had ~3K on them since I did the rebuild kit
Hi Cavero, I'm not sure about caster, but I'll find out. I'm working on the Steeda's with TJ. Can anyone speak to Maximum Motorsport's version? Good/bad? It is my understanding that the MM version re-uses one part of the OEM strut mount...and I don't think I want to do that. All comments welcome, thank you!
Is it the lower strut mount that's reused? Steeda HD mounts reuse the lower strut mount as well. But that's an all metal part, a metal cup so to speak, so I don't see a big deal in reusing it.
The stock mounts go bad because the rubber degrades and gets soft. I think pretty much all CC plates out there address that.
Based on the MM install pictures, it looks like you are correct - the lower strut mount ("stock lower spring perch"), is reused, and it is a metal piece.
Performance Manager at my speed shop wants to go with J&M. He says we need to have caster adjustment, as well, so Steedas are out (although he remarked what an excellent product the Steedas are). The MMs re-use the bottom part of the OEM strut mount, and although he said that is okay, he felt strongly that the J&M design of eliminating the entire OEM strut mount would be better for my specific application (Eibach Pro lowered).
LEXiiON
I know. I just spoke with Steeda, they said the same. I'll talk to my Performance Manager before the install. I think he's just being safe and covering all bases. Lack of caster adjustment was the deal-breaker for him for the Steedas. Bummer, I wanted those - such good reviews.
This. Tell em to pound sand if they don't like it
Looks like the kit in the 2005-2010 (& GT500's) come with a new spring perch (see instructions). This style has the pigtail seat molded into the fat rubber isolator (reused), rather than the perch itself. Plus, IIRC, the perch on the early S197's was plastic.
