J&M Adj. Panhard Bar- Steel or Aluminum?
Old Jun 6, 2013 | 11:29 AM
Ronin38's Avatar
Any particular advantages of one over the other? They're the same price...
Old Jun 6, 2013 | 02:47 PM
SoFlaBoss's Avatar
My aluminum J&M adjustable panhard bar is likely a little lighter than the steel version, and I'm very happy with it. However, adjusting my bar is not easy because the adjustment is on both ends. To adjust it, you have to install it with both locknuts loose, twist to adjust and lock down the driver's side, then lower the passenger's side to lock it down, then reinstall. I think the steel version has the locking mechanism in the center, making it easy to adjust and tighten with the bar in place.
Old Jun 6, 2013 | 03:03 PM
Ronin38's Avatar
Thanks. Do you ever have to readjust it once it's set?
Edit: I just took a better look at the pictures. You're right, the steel one has the adjustment feature away from the mounting points! Me likey!
Old Jun 7, 2013 | 07:14 AM
SoFlaBoss's Avatar
No, unless you change the springs again.
Old Jun 11, 2013 | 03:12 PM
Ronin38's Avatar
Okay, I received the bar today.
Does it come greased, or do I have to grease it? It doesn't say anything about that in the directions.
Edit: It's not greased. I also took Gabe's suggestion and put 90* fittings on it, so it will be easier to do after it's installed.
Mar 30, 2021 09:29 AM
Feb 10, 2017 07:12 PM
Sep 10, 2015 12:44 PM
