HELP!!! 2012 GT with H&R Springs...
Old Jul 9, 2013 | 06:59 PM
Michael Benetto's Avatar
I have a 2012 Mustang GT and recently had the H&R Race Springs installed... we forgot to transfer the rubber coil insulators off the factory springs. Whenever I hit any kind of bump, there is this horrible chunking metal on metal noise!!! will taking it apart and adding the insulators on the new springs solve the problem or do I need to buy something else??? Upper spring mounts??? THANK YOU ALL IN ADVANCE FOR YOUR HELP!
Old Jul 9, 2013 | 08:15 PM
Ajcruz1's Avatar
No you need to put the isolators on from the stock springs!!
Old Jul 9, 2013 | 08:18 PM
thanks! do you think that is what is causing that noise?
Old Jul 9, 2013 | 09:01 PM
Ajcruz1's Avatar
Well it doesn't have to be the ones from your stock springs but as long as you have isolators on your new springs you shouldn't here any noises.
Old Jul 10, 2013 | 02:43 PM
Brandon302's Avatar
Could also be the stock strut/spring mount.
Old Jul 10, 2013 | 04:02 PM
Womprat's Avatar
I ran these on my 2005, unless you added shocks, adj. panhard, axle bump stops, possibly a bumpsteer kit as well I would imagine, because these springs sat soooo low, you would have some issues. You are changing alot of geometry here, and check your pinion angle. And yeah, add some isolators..
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
boz
Oct 1, 2015 04:47 PM
JonathonK
Sep 29, 2015 09:27 AM
Horsev6
Sep 21, 2015 10:27 AM
VinnyD
Sep 18, 2015 01:19 PM
