FRPP "P" Springs Creaking on Compression
Old Aug 11, 2014 | 08:44 PM
Skandocious's Avatar
I installed these "P" springs myself a couple months ago and since installation the front ones have been creaking on compression. After compressing about an inch they creak down and then creak back up. Sounds mind of like a rubbery rubbing noise, like a low pitched squeak. Any ideas?
Old Aug 11, 2014 | 09:41 PM
Plim's Avatar
Have you checked if the bolt on the strut is still tight?
Old Aug 11, 2014 | 09:50 PM
The big nut at the top attaching to the top coil perch? No I'd have to remove the struts to check that (which I plan to do this weekend). I did check the lower attachment bolts shortly after installing the springs and they were tight (at least by a finger check)
Old Aug 11, 2014 | 09:56 PM
Plim's Avatar
You can check it without removing the struts. While everything is mounted, you can use a deep socket (22mm?) to see if it is loose. If you have an impact gun, you can even tighten it.
Old Aug 11, 2014 | 10:52 PM
You're right I forgot. I did also check them shortly after installing the springs. I'll check it again as it's been a month or two.
Old Aug 11, 2014 | 10:57 PM
You sure it's not your front lower control arms? There's a TSB for them. See if yours have the heat shield on them, protecting from the cats. The springs may have just helped the problem along...
Old Aug 11, 2014 | 11:05 PM
Plim's Avatar
If you have to re-tighten them, put a dab of paint on the bolt and the tread. It should help, from getting lose, and you can easily tell if it does.
Old Aug 11, 2014 | 11:07 PM
Plim's Avatar
Right, if the creaking sound, is like if you're, ... ehhh... jumping on an old bed, it might be the lower control arm bushings.
Old Aug 11, 2014 | 11:53 PM
Funny you mention that, my LCA bushings have squeaked since right after I got the car. I had ford replace them once but it came back within another 5k miles and they've squeaked ever since. Fact is, it would only squeak when I REALLY flexed the suspension out and not nearly this loud... But I didn't think about the fact that maybe the new springs changed up geometry... Hmmmm.
Could you point me to the TSB for the heat shields?
Old Aug 13, 2014 | 09:18 PM
Plim's Avatar
Funny you mention that, my LCA bushings have squeaked since right after I got the car. I had ford replace them once but it came back within another 5k miles and they've squeaked ever since. Fact is, it would only squeak when I REALLY flexed the suspension out and not nearly this loud... But I didn't think about the fact that maybe the new springs changed up geometry... Hmmmm. Could you point me to the TSB for the heat shields?
TSB 13-7-8
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
09-gt/cs
Oct 15, 2015 10:03 AM
GeoWett
Sep 30, 2015 06:40 AM
AJ_Trevino15
Sep 28, 2015 07:51 AM
