Eibach spring install, NEED HELP
Old May 23, 2012 | 05:20 PM
Tron84's Avatar
Am I missing something here? How am I suppose to use a wrench to loosen the 22mm nut on the top of the strut? If I use a socket I can't put a wrench on the strut to keep it from spinning.
Every installation instructions show a different upper strut mount where the nut is out in the open on top, not sunken down there.
This is on a 2012 GT. Any help would be greatly appriciated. I'm starting to get frustrated
Old May 24, 2012 | 05:38 AM
going for broke's Avatar
Impact wrench.
Old May 24, 2012 | 08:28 AM
corruptor's Avatar
I hit it with some wd40, let it sit for 15 min, then used a deep socket
Old May 26, 2012 | 08:21 AM
linelock's Avatar
I used an electric impact wrench but you may be able to lock some vice grips to the top of the strut shaft just under the mount to keep it from spinning.
Old May 26, 2012 | 09:31 AM
you don't really want to remove that nut untill your spring is compressed a bit. I used a impact gun to remove and install mine
Old May 26, 2012 | 03:18 PM
linelock's Avatar
yes, this for sure! but you can see his spring compressor in the shots.
dohc97
16
Sep 24, 2015 05:40 PM
Last1
Sep 5, 2015 01:23 PM
SMBJoshy
Aug 24, 2015 10:55 AM
RocStar69
Aug 21, 2015 07:33 AM
killaz05
Jul 24, 2015 08:49 AM
