BMR suspension install
Kelly from BMR suggested I mount the GT500 strut mounts inward instead of outward in lieu of using aftermarket adjustable camber bolts, so that is what I will be doing this weekend or next when I do my install. I'm just waiting on the konis to arrive and i have everything i need. "Bryan, I would skip the Bolts and just flip the USM around 180 degrees. Rarely do you need to swing that camber back in much after lowering. You should be around -1.2 to -1.5 after lowering, and flipping the mounts around. That would put you right in "spec"." Hopefully his advise helps others as well..
SMBJoshy
8/16/15 02:48 PM
