20x9 and 20x10 wheels tire fitment
Old Dec 26, 2024 | 01:25 PM
krcn's Avatar
Hello!
I have ford performance assembled handling pack installed on my 2014 GT so its 1inch lower (or even more) and I wanted to get 20x10 rear and 20x9 wheels.
What tire sizes will be the best to keep it a bit comfortable?
I was thinking 255 front 275 rear but what about profile of the tire?
Thanks in advance for help!
Old Dec 26, 2024 | 01:46 PM
05stangkc's Avatar
Welcome!
Lots of Pics & Discussion of Tire Size in This Thread!
https://themustangsource.com/forums/...ispreloading=1
KC
Old Dec 26, 2024 | 01:56 PM
05stangkc's Avatar
Also Be Mindful That You Have Proper Wheel Offset & If Car Has Larger Brembo Brakes That Wheel Choice Will Clear Calipers.
KC
Old Dec 26, 2024 | 01:59 PM
m05fastbackGT's Avatar
Originally Posted by krcn
Hello!
Also consider selecting the search function menu above on the home page, as you'll come across plenty of thread submissions which are directly related to tire and wheel sizes...
When the search window displays, type in 20x10" and 20x9" wheel fitment...
In the meantime, hope this helps...
Old Dec 29, 2024 | 09:52 PM
shaneyusa's Avatar
On my 2014 "GT" Roush Stage 2 I run the 20" Roush rims (Impossible to find now but... ) Size wise they are a 9.5" width. I run 275/35R20 on all four. Love to drive it and love the looks. Having all four the same size simplifies rotation as well. Just my 2 cents... Hope this will give you an idea of that size on our cars... FYI Mine is also lowered some 1 and 1.5" to level the ride.
Old Dec 30, 2024 | 07:50 AM
Bert's Avatar
if you want "comfortable" you do not want 20" wheels on a lowered suspension -- I would recommend 19" or even 18" wheels, if you haven't already bought the 20s
the 20" wheels force you to run low profile tires and the lowered suspension has less travel and stiffer springs than stock -- both of these run counter to "comfortable"
255 width on 9" wheel and 275 on 10" wheel sounds good for the width; but you need to figure out the aspect ratio and overall tire diameter
you can look up the original tire size on the door jam sticker, and then look up the overall diameter for that size -- on most of these cars, the original tire diameter is just a little over 27"
then you can look up the tire sizes you are considering on Tire Rack, or use an on-line calculator; and find the aspect ratio that gives about 27" overall diameter
here is one example for 255 tires for the front https://www.tirerack.com/tires/tires...omCompare1=yes
275/30 is a little small and 275/35 is a little big .... I'd probably go with the 275/35 to get a little extra sidewall but watch out for rubbing
https://www.tirerack.com/tires/tires...02XL&tab=Sizes
Old Jan 2, 2025 | 12:21 PM
shaneyusa's Avatar
Agree with the stiffer ride, but boy is it stable in the corners. I really don't mind the ride that much... If it was comfort I was after I would change things.
spotrox01
Dec 21, 2020 03:44 AM
Wolf Mxbee
05-09 Exterior Modifications
May 5, 2018 07:32 PM
Ddejesus523
1994-2004 V-8
Feb 23, 2012 11:12 AM
Roelito78
Nov 12, 2011 07:30 AM
LordBritish
19
Jun 9, 2006 05:41 PM
