2013 GT Metal Brake Fluid reservoir?
Old Jul 9, 2024 | 11:53 PM
OhNo5oh's Avatar
Hey all! Ive come across the (apparently) common problem with the master cylinder reservoir leaking at the cap and mid line seam. I wiped the tank, drove for about 50 miles, and it was just how it was when I started. Theres lots of forums about guys dropping the level or using Teflon tape to seal the cap. But those seem like Band-Aids for an otherwise serious issue. I dont wanna slap together some "maybe" fix and risk my paint.
Question is, does anyone know of/have experience with an aftermarket (preferably metal!) Tank? I want to fix it once and be done. I have yet to hear anywhere about a metal tank.
Old Jul 10, 2024 | 06:51 AM
NC14GT's Avatar
I wasn't even aware of this problem. Do you have many miles on your Mustang? Is it an age thing or mileage thing?
Old Jul 10, 2024 | 07:33 AM
05stangkc's Avatar
I Would First Try This As I Believe Some Have Merely Overfilled The Reservior And Some May Also Have A Worn Out Gasket in the Cap. The Fluid Mid Seam is Merely Where The Overflowed Fluid Had Dripped. Anyhoo it is Worth a Shot! Get a New Cap, Clean Well and Observe!
Also Some May Not Know When Installing New Pads & Compressing Calipers You Put Fluid Back into Reservior so if it Was Full When You Started The Brake Job You May get Spill over as Well!
Same Cap From 2005-2014!
https://www.fordpartsgiant.com/parts....html?pnc=2162
KC
Old Jul 10, 2024 | 10:48 AM
Bert's Avatar
I Would First Try This As I Believe Some Have Merely Overfilled The Reservior And Some May Also Have A Worn Out Gasket in the Cap. The Fluid Mid Seam is Merely Where The Overflowed Fluid Had Dripped. ....
KC
I think you may be on to something there -- the reservoir definitely looks like it is filled up to the tippy-top and could have easily overflowed
Old Jul 10, 2024 | 12:59 PM
m05fastbackGT's Avatar
Count me in as well... As for aftermarket metal brake fluid reservoirs are concerned, they do not exist according to my research!
Old Jul 10, 2024 | 02:02 PM
OhNo5oh's Avatar
It has 47.5k on odom. But I was scratching my head at the age thing. Maybe a decade of brake fluid sitting in a plastic container isnt a good idea?
Old Jul 10, 2024 | 02:03 PM
OhNo5oh's Avatar
KC
Thank you! As simple as it sounds I didn't think of just replacing the cap. Hopefully it'll be a nice and cheap fix.
Old Jul 10, 2024 | 02:17 PM
05stangkc's Avatar
You Are Welcome! It's Nice To Get a Thank You When We get a Lot of Dine & Dash Folks For Help! Do a Post We Reply & They Just Disappear without a Word! Makes The Members Less Likely To Pitch In! I get it!
Back in The Day When I Went Through Cars Like Ice Water I Had Plenty of Master Cylinders Where The Gasket Was Swelled Up at a Certain Point! Fill Master JUST BELOW Full Line Vs any bit Over! I think You Will Be Fine! That is After The New Cap!
Nothing Wrong With Getting a Brake Flush Either as Part of Maintenance! The Fluid Absorbs Water Over The Years! We Did These At The Dealership Quite a Bit!
https://www.bgprod.com/services/brakes/
Kc
Old Jul 10, 2024 | 05:37 PM
NC14GT's Avatar
Thanks...No I don't think the plastic container itself is an issue. I've had too many rides over the years and no issues with the plastic. My 23 year old Trans Am's plastic container is doing fine, as an example (85,000 miles). My '07 GT was fine too when I sold it 2 years ago (65,000 miles).
Old Jul 13, 2024 | 11:03 AM
OhNo5oh's Avatar
For what its worth I dropped the fluid level down to about 3/4 between min/max and did some spirited driving. No leaks! (Yet). Ill keep an eye on it and have a new cap on its way. Thanks again guys!
Old Jul 13, 2024 | 11:49 AM
Glad you found a solution... Hopefully there won't be any further leaks...
Old Jul 13, 2024 | 12:14 PM
05stangkc's Avatar
Hopefully The Issue is Now Capped Off!
Kc
Old Jul 13, 2024 | 09:17 PM
Kc
No pun intended!!!
WinterSucks
Oct 14, 2012 04:59 PM
Argetni
Dec 9, 2010 08:29 PM
DoctorQ
Jan 17, 2008 02:16 AM
Imatk
Nov 29, 2006 04:00 PM
Imatk
Jul 21, 2006 09:31 PM
