2012-2013 BOSS 302
Where is the extra weight coming from?
Old Aug 22, 2010 | 02:13 PM
JonW's Avatar
Despite non-power seats, aluminum wheels, no sound deadening and presumably no options, the Boss still weighs 30 pounds more than a GT. Where is that weight coming from?
Old Aug 22, 2010 | 02:18 PM
PTRocks's Avatar
Exhaust side pipes, the finned diff cover, the added front splitter, the larger radiator, the oil cooler, the extra baffles in the oil pan, probably the stiffer anti-roll bars, possibly the adjustable shocks.
Ltngdrvr's Avatar
Aluminum manifold instead of plastic for one.
#2- Heavier con rods(not much I'm sure but a little)
#3- seats maybe?
Old Aug 22, 2010 | 02:21 PM
PTRocks's Avatar
I've read the intake is also plastic, though it does have an aluminum cover.
Old Aug 22, 2010 | 02:38 PM
mwilson7's Avatar
Most of it is probably from the standard 19" wheels/tires vs. the standard 18's on the GT.
Old Aug 22, 2010 | 02:47 PM
Ministang's Avatar
This plus the "side pipes" are the major weight adders that I can see. If I had to warrant a guess, I'd say the wider wheels and tires are responsible for about 20 lbs of the added weight (5 lbs per corner) and the side pipes for the remaining ten pounds (5 lbs per side). The wheels and tires could be even heavier than my guess though, which would offset some of the missing sound deadener.
Old Aug 22, 2010 | 04:00 PM
MARZ's Avatar
Swamp Donkey Aficionado
The beefy, forged pistons are heavier than their cast counterparts, too.
Old Aug 22, 2010 | 04:26 PM
4x4xFord's Avatar
That front splitter is huge. Make it stiff enough to be useful, and it'll add 5-10 lbs easily.
Old Aug 22, 2010 | 05:38 PM
Fazm's Avatar
It also says estimated weight. Just wait until it's out for sure
Old Aug 22, 2010 | 09:12 PM
Dr Evil's Avatar
I thought it was the other way around? Composite shell.
Old Aug 23, 2010 | 10:41 AM
PTRocks's Avatar
By cover I mean the plate with the embossed logo on the top of the manifold.
Old Aug 23, 2010 | 11:15 AM
Josh69's Avatar
The brakes, wheels, tires and exhaust are most of it. Even though it doesn't have power seats or the additional options, all the wiring is likely still there which is common practice in today's vehicles, and that is a lot of the weight. For example, you bought a new Mustang without heated seats, the wiring would likely still be under the carpet. At least that's the way it was for my BMW's...it's easier and cheaper for the manufacturer to just have a single wiring harness, than to individualize based on content.
CiniZter
25
Apr 28, 2016 05:41 PM
14Glassback
Oct 4, 2015 08:52 AM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 5, 2015 11:50 PM
