When your build week arrives - visualize your build
I thought this might give you something to think about when your build week arrives so you can visualize the build process.
(The gaps represent moving to a different "line")
Body Assembled
Paint Main
Paint Roof
Hood Prop Rod
Faux Gas Cap Tape
Fuel Filler Hose
Body Tilted on Side
Fuel and Brake Lines
Fuel Tank
Cabin Air Filter
Hood Release Cable
Keys in Bag
Doors Removed - will be reattached later
Door Latch
Antenna Housing and Cable
Wiring Harness Interior
Wiring Harness Engine Bay Fuse Box
Rear Fascia
Door Weatherstrip
Trunk Weatherstrip
Computer Passenger Footwell
Taillights
Door Molding
Rear Speakers
Carpet
Brake Booster
Pedals Brake Clutch
Accelerator Pedal
Headliner
Air Cond Blower Interior
Inside Quarter Trim Panels
Inside Computer Module Center Trans Console
Radiator
Dashboard
Glovebox
A-Pillar Trim
Washer Bottle
Handbrake
Headlights
Front Fascia
Front Fuel Line
Muffler - Left
Engine Marriage to Body
Rear Axle
Rear Springs
Rear Axle Tightened
Front Suspension Tightened
Front Fender Liners
Rear Fender Liners
Rear Suspension Long Arm
Driveshaft
Rear Sway Bar
Exhaust Pipe
Interior Kick Panels
Steering Wheel
Steering Wheel Hub Air Bag
Hood Underpad
Coolant Bottle
Front Undertray
Wheels and Tires
TPMS Check
Brake Fluid
Battery
Front Console
Wiper Motor
Battery Blanket
Rear Window
Windshield
Rear Quarter Windows
Rear Quarter Trim
Black Plastic at Base of Windshield
Tire Inflator Kit
Driver Seat
Windshield Wipers
Gearshift ****
Rubber Hood Bumpers
Front Grille
Passenger Seat
Left Side Engine Beauty Cover
Coolant 1
Cold Air Intake
Gearshift Alignment
Doors Reinstalled
Crossbrace on Strut Towers
Boss Engine Label LS Number
Coolant 2
Power Window Switch
Right Side Engine Beauty Cover
Trunk Carpet
Floor Mats Placed in Trunk
Body Panel Alignment Checks
Door Gap Check
Fuel Fill
First Engine Start
Drive Off
Dyno Test
Electrical Driving Tests
Water Test
Examine Interior for Water Leaks
Electrical Test
Engine Pass
Rattle Test on outdoor rough road track
Body Assembled
Paint Main
Paint Roof
Hood Prop Rod
Faux Gas Cap Tape
Fuel Filler Hose
Body Tilted on Side
Fuel Tank
Cabin Air Filter
Hood Release Cable
Keys in Bag
Door Latch
Rear Fascia
Door Weatherstrip
Trunk Weatherstrip
Taillights
Door Molding
Rear Speakers
Carpet
Brake Booster
Pedals Brake Clutch
Accelerator Pedal
Headliner
Radiator
Dashboard
Glovebox
A-Pillar Trim
Washer Bottle
Handbrake
Headlights
Front Fascia
Front Fuel Line
Muffler - Left
Rear Axle
Rear Springs
Rear Axle Tightened
Front Fender Liners
Rear Fender Liners
Driveshaft
Rear Sway Bar
Exhaust Pipe
Steering Wheel
Hood Underpad
Coolant Bottle
Front Undertray
Wheels and Tires
TPMS Check
Brake Fluid
Battery
Front Console
Wiper Motor
Battery Blanket
Rear Window
Windshield
Rear Quarter Trim
Tire Inflator Kit
Driver Seat
Windshield Wipers
Gearshift ****
Rubber Hood Bumpers
Front Grille
Passenger Seat
Coolant 1
Cold Air Intake
Gearshift Alignment
Doors Reinstalled
Coolant 2
Power Window Switch
Trunk Carpet
Door Gap Check
Fuel Fill
First Engine Start
Drive Off
Dyno Test
Water Test
Electrical Test
Engine Pass
