2012-2013 BOSS 302
Weight: GT vs. Boss?
Old May 13, 2012 | 12:24 PM
UnrealFord's Avatar
I had the Boss weighed today on a certified scale,
Weight was with 1/4 tank of gas,
(Floormats, phone docking station on windshield)
without me.
Stock wheels in front, 15" Prostars w?MT Drag Radials in rear
WEIGHT=3560
Old May 13, 2012 | 02:49 PM
cloud9's Avatar
without me.
WEIGHT=3560
Great info. With my 20lb track wheels on I'm down roughly 100 lbs over stock with all the changes I made. That should put me under 3500 lbs in track form. My race seat weighs a few pounds less than the Recaro as well. The mufflers don't weigh 40lbs, but they are in the mid-20s. I dropped 30lbs total with the Corsas.
FWIW I started a weight reduction thread here that shows how much the changes I made are worth:
http://bossmustangsonline.com/boss-3...ght-reduction/
I haven't updated it for my suspension changes, but since the parts were all one-for-one I'm assuming the difference is negligible.
Old May 13, 2012 | 02:53 PM
11SHELBYGT500's Avatar
Originally Posted by cloud9
Great info. With my 20lb track wheels on I'm down roughly 100 lbs over stock with all the changes I made. That should put me under 3500 lbs in track form. My race seat weighs a few pounds less than the Recaro as well. The mufflers don't weigh 40lbs, but they're in the mid-20s. I dropped 30lbs total with the Corsas.
Don't forget the 100lbs of fuel
Old May 13, 2012 | 02:56 PM
cloud9's Avatar
Are you assuming he's pulling a tanker? If he had a 1/4 tank, you could only put 10 gallons in at 6 lbs per gallon to completely fill it. Most don't run their tank full at the track.....and you're burning 5 gallons a session
Old May 13, 2012 | 02:57 PM
No, I was saying with a full tank. Do you not run a full tank on the track? Ohh
Old May 13, 2012 | 03:08 PM
cloud9's Avatar
Right but he said he already had a 1/4 tank so the most he could add is about 60 lbs with a full tank. No I don't typically run a full tank but I do start sessions at 3/4. The saddle tanks seem prone to going dry on one side when you're sloshing it side to side in a track environment so I don't want to risk a lean condition by running too low.
Old May 13, 2012 | 03:10 PM
Yeah, I wasn't talking about him. I was talking to you and I didn't know you guys ran track with less than a full tank.
Old May 13, 2012 | 03:31 PM
UnrealFord's Avatar
I never run with more then a 1/4 tank at the track.
I run mine 1/4 mile at a time, at this time I havent road raced mine and dont believe I ever will,( Cant afford the wear and tear for Road Coarses, Paint, Brakes tires etc etc)
Fords Official weight says 3632 curb, which is exactly what mine would have been with full tank.
Old May 13, 2012 | 11:34 PM
cf6mech's Avatar
Ditch the boat anchor drive shaft for a solid aluninium one ,...lighter wheels and exhaust and alot of weight comes off fast.
Old May 14, 2012 | 04:42 AM
UnrealFord's Avatar
Im definetley gonna strip some of the heavy OEM exhaust for new ones.
Driveshaft im not to sure about yet, $700.00 is alot of money for something I might not get back results at track, (I didnt see any improvement from a OEM heavy shaft to FRPP Alum one on last car)
Old May 14, 2012 | 01:13 PM
cinque35's Avatar
Ditch the boat anchor drive shaft for a solid aluninium one ,....
^ he's right, you'll feel the diff the first time you drive it, the alum DS weighs 17lbs and it's not only rotating mass, it's before the differential so it has to spin 3.73x faster that the wheels. expensive but worth it
Old May 14, 2012 | 05:03 PM
cf6mech's Avatar
The only weak point in this car is in the driveline,....its were they decided to cut costs to come in at a price point. The Tranny/shifter and drive shaft although adequate, it comes up short in quality and performance, the driveshaft although quiet and void of NVH,...it weighs a ton, is over engineered and limits top speed on the street Boss,...the shifter is just pure junk, the China made transmission seems to be hit or miss for most,....long term I think we will all be sorry. The only real BIG difference between our cars and the 302s/302r cars are these components (with exceptions made for pure track car stuff).... I decided to keep the MT82 ,...because of that the first thing I changed was the driveshaft,...followed closely by the MGW shifter,.....it has made a big difference in performance.
Old May 14, 2012 | 07:55 PM
Overtorqued's Avatar
For reference, I weighed my '12 base GT (with no options) on my scales. The car was exactly as it comes from Ford (spare tire, jack, floor mats, etc) and had a FULL tank of gas. Total weight: 3608 lbs.
Old Sep 1, 2012 | 11:50 PM
clevor362's Avatar
Originally Posted by Knight
Think about a 1969 Boss 302, those still weighed 3400lbs and the new one does everything better than those.
I had for many years a 1970 Boss 302. I added sub-frame connectors and built up a homemade Boss 362 cid Clevor engine, hence the sign-in, and even with the larger (351) engine block, crank, etc it actually weighed in at only 3330 lbs on DOT scales with a full tank of gas. It wore 16" cast aluminum wheels with 255/50-16 tires. I never weighed them to compare with steel rims. Without the subframe connectors and with the lighter 302 block and internals it would have been closer to 3250. They were not nearly as heavy as the newer models. One of these days maybe I'll see what my LS actually weighs.
Old Sep 2, 2012 | 06:37 AM
JPC's Avatar
JPC
Originally Posted by ShaneM
the strut tower bar is probably 40 pound son its own. i couldn't believe how heavy it was on my 10, the only difference between the two is that the boss strut bar is curved. Also the factory mufflers weigh a ton. i would bet each of them are 40 pounds. one was heavier by the arm dyno than the flowmaster hush power muffs i swapped to.
anyone weight the strut tower bar?
how it compare to aftermarket bars?
Old Sep 5, 2012 | 06:19 AM
300AGT's Avatar
2011 300A Brembo GT, 3:73 gears that it (we have no spare tire stock) 3580 full tank of gas .
Old Sep 5, 2012 | 07:22 AM
UnrealFord's Avatar
Do you have a receipt from the scale? That weight is below Fords advertised.
Old Sep 5, 2012 | 07:35 PM
300AGT's Avatar
There is the only test done on a 2011 300A GT , Brembo and 3:73 gears the only 2 options on the car (same way i order my mustang GT) http://media.caranddriver.com/files/...e-jeopardy.pdf you see the test weight of the car 3580 lb. there the link to the test if you want to read it http://www.caranddriver.com/comparis...mparison-tests . When ford when to make a Boss 302 they started with my car .
Old Sep 5, 2012 | 07:40 PM
300AGT's Avatar
As a side note ford only made 60 300A GT with the brembos and 3:73 gears in 2011.
Old Sep 23, 2012 | 11:09 PM
  #40
Mikes5.0's Avatar
Good to know. I have one of the 60.
Automagically
2012-2013 BOSS 302
37
Feb 19, 2020 09:28 PM
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
TripleBlack14
Sep 17, 2015 07:48 AM
