2012-2013 BOSS 302
transmission and rear diff issues.....Need help with dealership not warrantying
Old May 10, 2012 | 08:10 PM
  #41
97GT12's Avatar
Originally Posted by adam81
I am not asking, nor expect, them to drop the trans or do major work on anything. There is a clutch inspection cover, that is a 5 minute job to unblot, to look at the TO bearing. This is what I asked them to do, they did NOT look at the TO bearing through the inspection cover..... They DID drain some of the fluid to check for shavings. They didn't find anything.
Trouble is the Ford shop manual says to remove the transmission to check the clutch slave cylinder.
I don't see any access cover that would work for the task in the illustrations and haven't spent enough time under the '12 to know if there's one there or not. I also don't see one in photographs of the MT-82 like these:
http://cgi.ebay.com/ws/eBayISAPI.dll...vip=true&rt=nc
If there is one it's going to be on the engine side and the clutch disc is going block the view of the TO/slave.
For the rear end all I was asking is to pop the diff cover, inspect the rear diff, and check fluid for shavings. They DID NOT do this....
As you can see I wasn't asking for anything to be taken apart, major work done, anything of the sort. Just simple inspections that were recommended to me by TWO different Ford Engineers on the Boss program...
Who pays when it comes up 'no problem found'? Is the dealer being cheap, probably. It does amount to a diff fluid change as far the dealer is concerned.
JonsMustang
Mar 5, 2016 05:44 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
fredovega
Which is Better
Sep 3, 2015 07:20 PM
