Trackey Tech
Trackey Tech
Talked to the guys at Ford Racing and they did confirm that either the black or red will work. That is a moot point because he did say that only one key will work at any time with the programming, so it looks like I will just do the red key myself. I had hoped by programming the black I could have spare copies of the "trackey"
I questioned him on the lost key issue since only one key will work at a time and he said that if you replace the red Trackey for a lost one, it will not activate the Trackey" programming but that if this did happen to someone they would call Ford Racing and a solution would be worked out without having to buy the program again. What that solution is he did not know, maybe they have to download the program again to match the new key and not charge you? Anyone's guess.
I thought I had read that if the red key was lost, you just needed another red key to activate the programming in the ECU. I might be misinformed, but I'm sure someone will have an answer.
Essentially you have to buy a new blank, have it cut, have PATS re-synched (?) and have the key programmed... all "at customer's expense". ECM doesn't need to be reflashed.
It's in the dealer installation notes on the Trackey site in the FAQ section (http://www.trackey.ford.com/trackey/...ons%20V1.0.pdf).
If you are running track tires different then the original size you better tell your dealer the size or they will put in the stock tire size.
Sent an email to FR and hope I get a response on the tire issue, also skip shift.
Since Trackey disables skip shift I wonder if the program will have a fault if the skip shift plug has been manually disconnected. Guess I could just reconnect it but I do not like street driving with it connected.
My other question to them is since different tire manufactures overall dimensions (W & H) differ even if the tire size is the same how much room for error in height is allowed in the programming when entering the tire size during Trackey installation?
I'm pretty luck as far as skip**** goes, my normal driving habit (easy) seems to trigger the skipshift every now and then.......but I'm already going to second when the dash indicates for me to go to 4th.......It's like I beat it to the punch. LOL
CiniZter
25
4/28/16 05:41 PM
DerekShiekhi
GT350
9/29/15 04:35 AM
