2012-2013 BOSS 302
Track wheels- 18" or 19"
Old Dec 9, 2010 | 10:06 PM
Berol's Avatar
For those of you who will have a dedicated set of track wheels, will you be running 18" or 19"?
What tires (brand/size/type) will you put on the wheels?
Old Dec 9, 2010 | 10:17 PM
66sprint200's Avatar
If you're talking real track wheels with real rubber on 'em then there's no question to ask..................
You get the smallest rim that will fit over the brake caliper, which is an 18".
The Boss 302R BBS wheel or an old Fikse FR500C rim or anything else that will hold a Hoosier R6 or BFG R1 or if you're budget conscious like me, a set of scuffed Grand Am Cup tires; Continental 275/35/18's.
The smallest diameter, lightest wheel with the largest contact patch and the least amount of unsprung rotating mass possible
Oh and damned the looks; performance is everything!
Old Dec 10, 2010 | 11:52 AM
Cusp's Avatar
+1, its more about the tire composition and profile than wheel diameter. Watch NASCAR, they don't run wagon wheels with rubber bands on them.
Old Dec 10, 2010 | 12:59 PM
cinque35's Avatar
+2... 18's
Old Dec 10, 2010 | 03:03 PM
cloud9's Avatar
Originally Posted by cinque35
+2... 18's
I'm planning on ordering these BBS wheels for my second track set to go with the Enkei PF01s I already have. Are the BBS a direct bolt up for the Boss or do you have to change out the wheels studs, use spacers or different lugs?
Old Dec 10, 2010 | 05:01 PM
Ask Blackbolt9 over on corner-carvers (also on svtperfomance). He works part time for Rehagen Racing. They are a distributor for these wheels as well as an end-user race team................. He should be able to answer.
I am curious too. I'd be next in line to buy a set for the track. I don't think my extra set of '07 GT500 rims would look so hot and I know they're a ton heavier
edit: his name is Tom
Old Dec 10, 2010 | 06:03 PM
06GT's Avatar
+3 for 18s.
Good luck finding 19" r-comps, anyways. And if you can, they're gonna be another $250/set minimum vs. 18s.
275/40/18 all the way around FTW. 35s if you want a little shorter effective gear ratio; 35s seem to slide a bit easier due to the shorter sidewall (less effective spring at the wheel).
Old Dec 10, 2010 | 06:15 PM
cloud9's Avatar
Hey Jeff I emailed them a couple days ago. I'll post up when I hear back. Yea I've got an extra set of GT500 wheels too but at 29lbs a piece I may just use them to hold up my deck umbrellas.
Old Dec 10, 2010 | 08:18 PM
Overboost's Avatar
Just got my track wheels today. Roush RR03 Forged 18x10 wheels. Using BFG G-force TA KDs in 275/40/18 to start for track tires.
Old Dec 10, 2010 | 09:42 PM
Berol's Avatar
Cool. Thanks to everybody for replies.
I should have mentioned before that I am not on a limitless budget. This is something that is more or less going to be a hobby, and I'll see limited track time.
At this point, I'm honestly considering picking up a cheap set of 18" 2010 GT500 wheels and putting R-comps on them. Yeah, they're not the lightest wheels in the world but they're cheap, they will fit over the brakes and they're fairly wide (9.5"). I'd also consider the Laguna Seca style wheel from FRPP (with black paint vice red), but I'm guessing those wheels will probably run $400+ each, and they are 19s.
Originally Posted by 06GT
+3 for 18s.
Thanks, this is exactly the problem I was running into- I couldn't find a good tire selection in 19" on tirerack. It's good to know a size to have as a reference as well.
Nice. Post pics!
Old Dec 10, 2010 | 09:48 PM
jsnyng's Avatar
That's exactly the choice I made with my car. I could afford the wheels and tires I wanted, but I couldn't afford the rest of the suspension upgrades I wanted. I went with the SVT GT500 wheels and was able to buy Koni Sports, a Fays2 Watts Link, and Strano Adjustable Sways. I figured I'd rather have an entire car setup well than have the lighter wheels that I wanted to begin with. And, the autocross season doesn't start up again until February which means when my tax returns come back in March, I'll have the $ to get track only wheels/tires.
Old Dec 10, 2010 | 10:55 PM
06GT's Avatar
Those Roush wheels are legit, have a set myself (the painted ones from the TP) for track wheels.
I know you got a killer deal on those tires, you'll need to step up to a real r-comp after you burn those out, though. Can't rotate those KD's either :-/
Old Dec 10, 2010 | 11:19 PM
Overboost's Avatar
For the price it was stupid not to. I could have got a set of R-comps, but it would have been triple (at least) what I paid for these tires to start.
You can't rotate the KD's? I know they're directional. You can still swap them front to back, right?
Old Dec 10, 2010 | 11:35 PM
06GT's Avatar
That's as good as it gets
Old Dec 10, 2010 | 11:38 PM
Overboost's Avatar
Nice. Post pics!
I need to clean them up tomorrow and put them away. Tires all have 95% tread or better on them.
Old Dec 11, 2010 | 09:07 AM
cloud9's Avatar
I will sell you a set of 2007-9 GT500 wheels that are a little worn from track use. They will be cheap. Let me know if you're interested.
Old Mar 21, 2013 | 12:42 PM
JCPerformance's Avatar
+2... 18's
Care to sell a set of those?
Old Mar 21, 2013 | 06:06 PM
ConeBoss's Avatar
Enkei PF01 18x10.5
Cheap, light and strong.
http://i131.photobucket.com/albums/p.../WP_000146.jpg
09-gt/cs
Oct 15, 2015 10:03 AM
Kalel08
Sep 29, 2015 03:06 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Sep 8, 2015 10:45 AM
