2012-2013 BOSS 302
looking for 18 inch track wheels....light and inexpensive
Old Oct 11, 2011 | 06:26 AM
adam81's Avatar
I am looking for 18 inch track wheels. Fronts 18x9.5/10 and rears 18x10.5/11. I am looking to spend $500 or less per wheel. The wheels must be light around 21-22 pounds as a max weight. I really like the design of the 302r wheel and I am looking for something similar to that in either flat black or possibly bronze. However I am open to whatever is out there.
Again the rim size must be as listed. I run wider tires for the track and these are the rim sizes that work with the tires I will use.
Any ideas. Right now I am tracking Enkei PF01s as a wheel that fits my criteria.
Old Oct 11, 2011 | 06:27 AM
m4a1mustang's Avatar
Have you checked to see if the Enkei RPF01s will fit? I think they come in those sizes.
*edit* Just read the last line of your post.
Old Oct 11, 2011 | 06:49 AM
Jimmy Pribble's Avatar
http://www.tsw.com/alloy_wheels_Nurburgring.php
Jimmy
Old Oct 11, 2011 | 06:59 AM
Forgestar F14s would also be a similar weight to the TSWs.
Old Oct 11, 2011 | 07:14 AM
I should add that the TSW meet all of your criteria (size, weight, appearance), except I don't know for certain that they have a fitment for Mustangs. Their fitment guide was down, so you might have to call.
Jimmy
Old Oct 11, 2011 | 08:46 AM
5 DOT 0's Avatar
Jimmy
They do. The TSW and Forgestar use the same manufacturing process.
Old Oct 11, 2011 | 09:32 AM
OLOABoss's Avatar
Yes I know it would up your budget a little but I am going with CCW's
http://www.ccwheel.com/wheelprofiles...y.php?id=SP16a
Light and Forged, the real thing, and only a few $$ more. John will also steer you right with offsets that are correct for the Boss not some generic offset like the Enkie which are not ideal for either the front or rear.
Peter
Old Oct 11, 2011 | 09:39 AM
SoCalBoss's Avatar
Originally Posted by OLOABoss
...with offsets that are correct for the Boss not some generic offset like the Enkie which are not ideal for either the front or rear.
I have been told that it is important to get the correct offset for your car. Otherwise, you will wear out your wheel bearings a lot faster. And I don't think replacing bearings is a trivial job.
Old Oct 11, 2011 | 09:46 AM
fuhrius's Avatar
ccw's
as mentioned, definitely will run you higher than your budget, but their product is very good and their service is top notch.
Old Oct 11, 2011 | 09:53 AM
908ssp's Avatar
These are slightly lighter TSWs and the same price and rotary forged. Not as common a style which is one reason I went with these but mine are 20".
http://www.tsw.com/alloy_wheels_interlagos.php
Old Oct 11, 2011 | 09:54 AM
06GT's Avatar
Light, inexpensive, good quality.
Pick any two.
Old Oct 11, 2011 | 10:00 AM
5 DOT 0's Avatar
Do you know if these come in the proper offsets in 18x9.5 and 18x10.5?
Old Oct 11, 2011 | 10:33 AM
CaptDistraction's Avatar
Pick any two.
This.
Old Oct 11, 2011 | 10:35 AM
fuhrius's Avatar
true for everything
Keith Bontrager of mountain bike fame is well-known for his quote, which drove his design philosophy:
Strong. Light. Cheap. Pick two.
Pick any two.
Old Oct 11, 2011 | 12:53 PM
adam81's Avatar
I talked to thee different people that all called tsw direct. In these sizes the offsets will not fit for the nurburgring wheels. They only fit with front 8.5 rear 9.5
Old Oct 11, 2011 | 12:54 PM
adam81's Avatar
No one is saying cheap.... Inexpensive is what I am saying. $1k per wheel for HRE or whatever is ridiculous...
Old Oct 11, 2011 | 01:45 PM
5 DOT 0's Avatar
I went to the Forgestar factory in OC this past Spring and checked out their wheels. They look great and look to be a solid company. I don't like the idea of centering rings so I bought the Ford Racing SVT PP wheels instead for street use. Maybe the rings are not a big deal. If it's not they have 9.5's and 11's with the proper offset and guys have been running them. They are about $1,500 a set.
http://www.elementwheels.com/proddet...95fs%2Dcf51811
http://www.elementwheels.com/proddet...fs%2Df14gm1811
http://www.forgestar.com/v2/wheelsf14.php
Old Oct 11, 2011 | 02:03 PM
06GT's Avatar
Pretty good price on 302R wheels w/ free shipping... http://www.fordracingpartsdirect.com...1007-r1810.htm
Old Oct 11, 2011 | 02:19 PM
JScheier's Avatar
Yes I know it would up your budget a little but I am going with CCW's Peter
Not one to argue, but CCW's are not as light as the Enkie wheels posted. I've owned 4 sets of CCWs in 16", 17" and 18" diameters from 9" to 12" width. They aren't that light.
They are incredibly strong... and re-buildable. put the car into a curb? Purchase another wheel half. I've bounced them off of 1000s of curbs and never bent one (lucky!). I've got a 17x9 setup for an M3 sitting in my basement right now as I refuse to give them away (they make pretty end-tables ).
However, if there ever was a company to stand behind it's wheels, that's John and CCW. He has over-nighted me parts when I was at a race and in a bind. He's walked me through rebuild steps at 11pm... he's worked with me on custom offsets and fitments. You'd be hard pressed to find a company like that today.
Old Oct 11, 2011 | 02:32 PM
fuhrius's Avatar
re: ccw weights
my last set of ccw's were their 'classic' 3 piece design with the lighter weight 'track' hole option (as Jscheier points out...they're rebuildable)...and the weights were 19.5lbs for 18x9.5 and 20.2lbs for 18x10 - that's pretty light.
