2012-2013 BOSS 302
Track Key Instructions
Old Oct 31, 2011 | 08:33 PM
kyfigfam's Avatar
http://www.fordracingparts.com/track...ions%201.0.pdf
Looking for an explanation as to what the dual rev limiter does and ran across this.
Old Nov 1, 2011 | 10:47 AM
ulev1st's Avatar
Sweeet.
Old Nov 1, 2011 | 06:18 PM
roketman's Avatar
This is so cool! Worth the wait! Mine is being installed Wednesday !The only problem is I am out of track days till spring! I want to cry !Oh well ,something to live for !
Old Nov 1, 2011 | 06:19 PM
Tob*'s Avatar
While doing my daily scouring of the web for anything new in the Mustang world I cam across this (The dealer pdf is just as interesting http://www.trackey.ford.com/trackey/...ons%20V1.0.pdf ).
Under "Lopey idle"
Removing the side exhaust blockoff plates results in a significantly more distinctive exhaust note when lopey idle mode is enabled.
That is so incredibly badass.
Old Nov 1, 2011 | 07:53 PM
5 DOT 0's Avatar
Under "Lopey idle"
QFT The cars at Track Attack had the stock restrictor plates and the lopey idle still sounded cool. I can't wait to hear it with less restrictive plates.
Old Nov 2, 2011 | 06:32 PM
2012YellowBoss's Avatar
When I read the dealer pdf I was thinking the same thing about the Miller cars.
Old Apr 16, 2012 | 11:10 AM
2 Go Snake's Avatar
Question
Is the track key being offered for the 2013 Boss 302 ? I dont recall any mention as to wether or not the 2013 Boss 302 will have the track key.
Old Apr 16, 2012 | 11:18 AM
Cali-Nt54's Avatar
It will be coming out. From what some people on another forum have said, they aren't quite done with the programing yet.
Old Apr 16, 2012 | 12:24 PM
Dig-It Racing's Avatar
Programming of what? The drivetrain is the same as MY12.
Old Apr 16, 2012 | 12:31 PM
bpmurr's Avatar
The system interface with the Track Apps display is now different. That is probably what's requiring some modification to the 2012 code.
Old Apr 16, 2012 | 12:38 PM
But isn't that just a new way to view already available data?
Old Apr 28, 2012 | 11:20 AM
2 Go Snake's Avatar
Smile
Just read on Mustangs Daily about the 2013 Track Key. Good news. Sounds like the Track Key is improved for 2013.
Old Apr 28, 2012 | 12:48 PM
5 DOT 0's Avatar
What's improved?
http://mustangsdaily.com/blog/2012/0...rting-may-1st/
Old May 11, 2012 | 03:54 PM
93 LX 5.0's Avatar
Anybody have a pdf of the v 2.0 install instructions ?
Nevermind, I found it.
Old Dec 19, 2012 | 12:08 PM
flight96's Avatar
Is the Track Key option on all Boss 302's ?
Old Dec 19, 2012 | 07:31 PM
mattlqx's Avatar
A Ford dealer can install TracKey on any Boss. *But* they might not have any clue what the TracKey is depending on who you talk to at the dealership and the frequency of them actually working on these cars.
Try and find the dealer in your area that handles the most volume, they're probably your best bet. You can order the packet direct from Ford Racing and bring it to them if none of them have a clue already.
Old Jun 13, 2013 | 11:03 AM
canadian_mca's Avatar
Small discrepancies in version 2.2 for Dealer Install
Had the Track Key installed yesterday by Campbell Ford, Ottawa, Ontario, Canada. No issue with it as I felt the lopey idle shortly after I drove off. On a 30 miles run (25 miles hwy), felt like back in 70's. Car shaking a bit, detonation, couple backfires when slowing down, just like the good old 70's. Yes, it does kick in very shortly after driving off and it will bling in display.
Now for discrepancy.
Dealer Instructions, para 27 and 30. PCM File name listed is for 2012. 2013 have different one. They had to contact Ford Perf to get that info. Ford plse take note and reissue instructions under version 2.3 with corrected info
2012 - (listed) CR3A-SEMABM-5BC
2013 (Not listed) DR3A-SEMABM-5BB
Pass the info to your tech if u r getting the key installed on 2013.
Took longer than one hour, but got charged only 1 hr.
Old Jun 13, 2013 | 08:03 PM
Had mine installed with no problems I love it!!!
Old Jun 14, 2013 | 07:26 AM
FordService's Avatar
I’m sure your dealer’s call has alerted the Ford Performance Group to update the info, canadian_mca. Thank you for the info!
Deysha
Old Jun 30, 2014 | 02:31 PM
flight96's Avatar
I should have read this before I took my car in.
Took it in today to get the Trackey installed !! Now Im driving a loaner . They said that halfway through the process the program crashed. Now they can't get it started again. They have never done one before .
