Track Key Instructions
http://www.fordracingparts.com/track...ions%201.0.pdf
Looking for an explanation as to what the dual rev limiter does and ran across this.
While doing my daily scouring of the web for anything new in the Mustang world I cam across this (The dealer pdf is just as interesting http://www.trackey.ford.com/trackey/...ons%20V1.0.pdf ).
Under "Lopey idle"
That is so incredibly badass.
Under "Lopey idle"
Removing the side exhaust blockoff plates results in a significantly more distinctive exhaust note when lopey idle mode is enabled.
Under "Lopey idle"
Under "Lopey idle"
Originally Posted by 2 Go Snake
Is the track key being offered for the 2013 Boss 302 ? I dont recall any mention as to wether or not the 2013 Boss 302 will have the track key.
A Ford dealer can install TracKey on any Boss. *But* they might not have any clue what the TracKey is depending on who you talk to at the dealership and the frequency of them actually working on these cars.
Try and find the dealer in your area that handles the most volume, they're probably your best bet. You can order the packet direct from Ford Racing and bring it to them if none of them have a clue already.
Small discrepancies in version 2.2 for Dealer Install
Had the Track Key installed yesterday by Campbell Ford, Ottawa, Ontario, Canada. No issue with it as I felt the lopey idle shortly after I drove off. On a 30 miles run (25 miles hwy), felt like back in 70's. Car shaking a bit, detonation, couple backfires when slowing down, just like the good old 70's. Yes, it does kick in very shortly after driving off and it will bling in display.
Now for discrepancy.
Dealer Instructions, para 27 and 30. PCM File name listed is for 2012. 2013 have different one. They had to contact Ford Perf to get that info. Ford plse take note and reissue instructions under version 2.3 with corrected info
2012 - (listed) CR3A-SEMABM-5BC
2013 (Not listed) DR3A-SEMABM-5BB
Pass the info to your tech if u r getting the key installed on 2013.
Took longer than one hour, but got charged only 1 hr.
Received 2,252 Likes
Had mine installed with no problems I love it!!!
Deysha
Took it in today to get the Trackey installed !! Now Im driving a loaner . They said that halfway through the process the program crashed. Now they can't get it started again. They have never done one before .
