Torsen Differential & Recaro Option Opinion's.
I looked up the Alcantara on the Bimmer forums and apparently they love it in their cars even over leather or leatherette. It's been all the rage for a few years now.
I just hope it's not something that will be found out that it will look like crap in a few years.
Well I have to decide in a few days on this and I'm still concerned that I'll make the wrong decision,,,,please if anyone has anything more to add, lay it on me.
LQQK
LQQK
Founding MOTM
Committee Member
Committee Member
I can tell you the Recaro seats used in the Evo cars are good seats, even after extended trips. However, I wouldn't take my word as law due to the fact I do have a small frame and i'm quite tolerant of seats. I will also say of all the "race type" seats i've sat in, those Evo Recaros are so far the most comfortable and tolerable of the bunch.
I would go for the seats and the diff. You never know if the seats will hold a crazy sale value if you eventually wanted to part ways with them. Of course, the more performance options you put on the car(since its a performance-based car), the higher your resale value of the entire vehicle will be.
Otherwise, for the price (which we don't know at the moment), it might be overkill. Based on how I would use the car, I am not planning on them. I would, however, add the Ford Racing brake cooling kit to maximize the fade resistance for periodic high performance driving experiences.
I wouldn't be too quick to make choices on things we don't know enough about yet.
While the order banks will open Nov. 8th that doesn't mean you have to order then. Hopefully all the info comes out by then but if not I would wait a few more weeks. I'm sure your dealer isn't going to bounce you for not ordering on the 1st day.
I'm thinking the Recaro's will be a good seat. The Torsen Diff. is something I would most likely pass on.
LQQK
How much will you drive the car at higher limits on a racetrack? Or would you want it because it fits the character of the car? The Torsen differential would offer you excellent cornering in aggressive high performance driving. The stock limited slip would be at a disadvantage if you raced a lot in terms of wearing out the clutches lots potentially. The Torsen might be overkill for just street driving, although the last generation Camaro and Firebird had them. Some additional technical information on the cornering benefits can be found here - http://www.zhome.com/ZCMnL/tech/Torsen/Torsen.htm
Aren't they (Recaros/Torsen LSD) bundled together as a option for the regular Boss? Just have to do without both in that case. I like the Torsen diff. simply because you don't have to deal with eventually replacing clutches or needing friction modifier when changing gear oil.
I don't plan on tracking the BOSS, So, I guess, I want it because it fits the character of the car???
Do you, or anyone, feel it would affect spirited daily type driving adversely or would a person not know the difference between having stock or Torsen installed?
My uneducated-guess is, order the Recaro/Torsen option, because, it will help not only for resale, but long term durability and it wouldn't hurt to have it in-case I get the urge to embarrass myself at a track.
LQQK
Very techie info in the link you provided (still trying to wrap my mind around it).
LQQK
LQQK
My understanding is that the Tor Diff. doesn't hold up very well to drag style starts. I won't be taking the car to a drag strip but I'm certainly going to find empty open roads and do some quick burn out starts. What I won't be doing is ripping around a corner at high speeds where the Tor. Diff. is really suited for.
LQQK
LQQK
Good link. THX. The only disadvantage I see with the Torsen is that it may have more rotational mass than an clutch operated LSD. This would be a disadvantage in drag racing potentially. Other than that it seems like the way to go for the character of the car even if it is not tracked.
Jim
For me, the ultimate deciding factor is price on these two. If this was an extra $1000, then I would get it. I suspect it's probably going to be more than that ($2000+), based on looking at the prices in the aftermarket for the individual items.
Justufying the extra $1000 then would simply because these parts are more in keeping with the car's character as opposed to the added funtionality they would bring. On the street, it's not that easy to get to the high limits of cornering as in race conditions (unless you like hanging it out illegally and endangering others
I guess we will soon know.
Jim
Jim
#40
A Detroit Truetrac also uses helical worm gears to provide L/R torque biasing - the orientation of the worm gears are different compared to the Torsen. It too has similar shortcomings. Unless you're thinking Detroit Locker - a different beast and definitely much stronger, but not nearly as smooth with limited slip action.
http://www.eaton.com/ecm/groups/publ.../ct_126000.jpg
