2012-2013 BOSS 302
Tires...
Old Dec 17, 2012 | 10:36 PM
BOSSPOWER's Avatar
Tires...
Would this size work without rubbing...
Tire Size Rear: 305/30-19 | Tire Size Front: 265/30-19
Thanks,
Manuel
Old Dec 18, 2012 | 09:11 AM
GrabberBlue310's Avatar
You shouldnt have a problem running that width.
Old Dec 18, 2012 | 03:18 PM
fking1's Avatar
The stock 9-1/2" rear rim width may be too small for 305's , but, the front 9's should handle 265.
Old Dec 18, 2012 | 10:04 PM
bob's Avatar
bob
Check the tire manufacturers data sheet for approved rim widths.
Old Dec 22, 2012 | 12:30 AM
racered302's Avatar
275's fit pretty well on 9.5 rims, 285's are perfect. A half inch won't matter if it's only for the street. I have 255's on 9.5x18 on the front and they fit, but I wouldn't track them. Too many variables, they are slightly stretched but nothing to be concerned about. I've read about others using 275 as a square setup with no rubbing up front front. Can't always trust what you read.
Old Dec 22, 2012 | 05:05 AM
AlsCobra's Avatar
A Man Just Needs Some....
265/30 and 305/30 is gonna be a height difference. Might mess with the abs or traction system but not sure. 265/35 would be a closer match to height. The 265 and 305 is not the actual width. Unless you want taller back tires.
Old Dec 22, 2012 | 07:58 AM
bob's Avatar
bob
A 9.5" wide rim is generally the widest rim you can fit a 255/45 and lower aspect ratio tire to. The biggest benefit is steering response and lateral load capability. IIRC a 9.5" rim is about the most narrow rim a low profile 285 can be fitted to. In contrast to the 255 it offers slower steering response and lateral load capability although its dynamic grip might be better by dint of offering more rubber on the ground when your hustling a car around corners and over bumps.
A 285 on a 9.5" rim also offers better protection for the rim as the aesthetically pleasing bulge provides a decent barrier before the rim comes/into contact with something.
@ Al, I'm running a 255/45R18 in combination with a 305/45R18 drag radial right now with a coupla thousand miles/on the clock with no Ill effect.
Old Dec 22, 2012 | 08:26 AM
AlsCobra's Avatar
Good to know. The different height a few years back was messing with some vehicles. Abs and traction.
Old Dec 23, 2012 | 06:56 PM
bob's Avatar
bob
IIRC it used to be that the tires had to be within 4% of each other to eliminate issues with ABS and TCS and its interesting to note with my programer that it only asks for the rear tire OD (expressed in revs per mile) rather than both the front and rear tire ODs.
Old Dec 25, 2012 | 07:20 PM
steveespo's Avatar
I ran 645 mm tall front and 680 mm tall rear slicks at Pocono and Lime Rock and was worried if the different diameters would cause issues. Surprised pleasantly that there were none and both ABS and TC functioned properly in normal, sport and off modes.
Steve
texastboneking
Nov 1, 2012 09:10 PM
MRGTX
Aug 31, 2011 10:19 PM
PATAN
05-09 Exterior Modifications
25
Dec 25, 2007 02:29 PM
