For those hoping for a Shaker hood scoop for the 2013
Interesting new part available in the 2011 Ford Racing catalog.
M-16612-SHKB - 2011 MUSTANG GT SHAKER HOOD SYSTEM P.244
• Utilizes factory air box
• Includes engine cover with “Ford Racing” badges and cast aluminum
scoop that is reminiscent of the original 1969-1970 Shaker models
• Kit includes all mounting hardware, ductwork, template and detailed
installation instructions
• Installation can be completed in three hours or less with basic
shop tools
shop tools
After thinking for a bit, I'm sure it won't fit the Boss intake, but it would be a nice detail for those looking to make a Mach 1.
I seriously doubt it adds power, it should draw essentially the same temperature air as the stock intake.
I'll pass on that.
I've owned a pair of Mach 1's. My '03 Mach 1 had the factory shaker. I spoke with an engineer from Team Mustang back when the '03's were first launched, and I was told that at 80+ mph the shaker offered a 25hp bump. Over at the Mach1Registry, there are a couple of guys who plugged their shakers and made back to back runs at the dragstrip with and without it plugged and found a 1 or 2 tenth improvement in ET's. In summary, it's less about the temperature as it is about the ram effect.
I believe the shaker was made available for the 2011 GT aftermarket but not the V6. It is too bad they did not make it an option for the Boss but like most of you I will not add one. I will have to order it on the 13 if they make it available
It will look good with the 70 graphics.
Also, the 2003 shaker ducting looks to be much more free flowing than the 2011 version.
Of course, the final proof will be found at the track.
It has been said that a scoop in the middle of the hood offers little performance gain since this is a relatively low pressure zone. The only way that makes sense is if the scoop is tall enough to reach the high pressure zone above the hood such as on a Pro Stock drag car. Not very practical on a street car though. Having the air inlet in the grille should provide more of a ram effect since that is a much higher pressure zone but it also requires a less aerodynamic frontal area. Using a cowl induction type hood that draws air from the base of the windshield is probably the best compromise since it takes advantage of the high pressure zone at the base of the windshield but does not induce additional drag. A good example of this is a NASCAR stock car. Rather than take air from the grille which would require a bigger open area on the front of the car (more drag) or place a front facing scoop on the hood they pull air for the carb from the base of the windshield. Why do you think the air intake for your car's HVAC system is at the base of the windshield? No offense, but placing a scoop in the middle of the hood is more about appearance than performance. There is absolutely nothing wrong with that but those two goals are sometimes conflicting.
well said...but cowl induction for Chevy!! Lol all joking aside your theory makes sense but i love the look of the shaker...but if any hood goes on my car it's going to be the 302S hood
