2012-2013 BOSS 302
View Poll Results: Which lowering springs would you go with.
Eibach Pro Kit
15.00%
Eibach Sportline
0%
H&R
5.00%
Steeda Competition
20.00%
Steeda Sport
40.00%
Other
20.00%
Voters: 20. You may not vote on this poll
Spring options
Old Apr 25, 2011 | 12:42 PM
Zoldier's Avatar
Spring options
Looking for some opinions on what springs would work best with our adjustable shocks. Not sure how these spring rates compare to our factory springs. I was looking at the Steeda competition springs but those might be too stiff so now I'm considering Eibach Pro Kit. I do plan to track the car every once in a while.
Your thoughts.
Old Apr 25, 2011 | 01:10 PM
Chris23's Avatar
Your thoughts.
I have been thinking about the Steeda springs as well but I am also wondering about the spring rate. The other thing is if the rates are not to much different I really only want to put them on the rear. I wonder it steeda would just sell me two rear springs?
Old Apr 25, 2011 | 01:50 PM
ShaneM's Avatar
It wasn too long ago that i went through this w my 10. After talkkng with people that sold just about all the springs the steeda sport were what i went woth and loved them. They pair well w d-specs not sre how far off boss dampers are from d-specs though. The thi. I remember was them telling me to stay away from springs w progressive rates if you want to maintai. Ride quality.
Old Apr 25, 2011 | 02:30 PM
5 DOT 0's Avatar
Steeda Sports. The sports will lower the front about 1/2" and the rear just over 1". You really need to try and match up the spring rates.
Old Apr 25, 2011 | 02:35 PM
06GT's Avatar
Too hard to tell without knowing the rates of the stock springs and each of the aftermarket ones
Old Apr 25, 2011 | 02:54 PM
Zoldier's Avatar
I have the stock spring rates but not the aftermarket ones.
Boss-
26.0 N/mm front and 32.4 N/mm rear coil springs
Boss LS-
24.0 N/mm front and 33.5 N/mm rear coil springs
Old Apr 25, 2011 | 03:57 PM
sam strano's Avatar
Your thoughts.
Be careful assuming... Steeda Comps are both softer and taller than Eibach's are.
As for the Boss shocks, they are Tokico Illumina's (an older adjustable design than the D-spec and frankly not as flexible). I don't know the damping on them exactly, but they are meant to team with the stock springs which are not super stiff in front, about right in the rear (just too tall IHMO). I think any normal, moderate type lowering spring should be an ok match with those dampers. Just be advised that just because the comes stock with that, that does not mean they are the best shocks you could get.
As for what particular springs will work on the car itself the same things we do on normal S197's still apply... same chassis, same kind of weight...
Now that my GT is fixed, I'm getting some good data and can progress the setup. On 315 Hoosier's I'm now seeing 1.2g and the car is fast. Back to back showed an almost 4 second difference vs. a Shelby GT I also setup on the same compound tire over a 50-55 second autocross. And my GT is stock powertrain wise w/3.31's, this is just suspension and wheels/tires.
Old Apr 25, 2011 | 04:03 PM
sam strano's Avatar
I can do that for you if you like... but one of the things that makes a set of those better is the front springs make for what I think is a better balance.
Old Apr 25, 2011 | 04:52 PM
Zoldier's Avatar
Thanks Sam. I spoke to someone that had the Steeda Comp's and they said they were a lot stiffer. I take it from your post you are running the Pro kit or the sportlines.
I'd like the look of the sportlines but not sure if thats too much of a drop without having to worry about camber and such.
Old Apr 25, 2011 | 05:09 PM
300AGT's Avatar
When i went to lower my 2011 brembo GT ( hate the stock ride hight) i talk to Sam Strano . I when with a set-up Sam said work good on a DD mustang (Steeda Sport springs & koni STR.T shocks and Struts ) The set-up work just as Sam said it would. It made the car handle better , look better and the ride was very good for a lower car . Thxs Sam for the good Info.
Old Apr 25, 2011 | 05:16 PM
5 DOT 0's Avatar
Thanks Sam. Just for the record you run Steeda springs correct? Can you please post the spring rates of the Steeda sports.
Old Apr 26, 2011 | 08:41 PM
Zoldier's Avatar
Boss Stock: 148/185 lbs/in
Boss LS Stock: 137/191 lbs/in
Pro Kit rate: 160-274 lbs/in
H&R Super Sport: 275/245 lbs/in
H&R Race: 325/385 lbs/in
Steeda Competition: 225/185 lbs/in
Steeda Sports: 200/175 lbs/in
Only ones I've been able to find.
Old Apr 27, 2011 | 03:49 PM
Zoldier's Avatar
Based on the numbers above I think I'm going to go with the Steeda Sports. I'm not sure how the rear end will feel being a little lighter than the stocks but the difference in the front should help with nose dive under heavy braking.
Old Apr 27, 2011 | 10:00 PM
Swoope's Avatar
there are two different steeda sports, one is progressive the other is linear. the linear ones are the way to go..
this is stuff i have learned from reading several mustang forums, i tend to lurk in the road racing or handling section.. strano it the one that makes a point to make the difference between the springs known.. i would give him a ring..
guy knows his stuff, and has the wins to prove it..
sam if you happen to read this, where did you or they find the chaffed harness?
beers
Autotooner
Nov 24, 2017 12:42 PM
RCooke08GT
Feb 19, 2017 03:03 AM
GeoWett
Sep 30, 2015 06:40 AM
Evil_Capri
Sep 25, 2015 12:56 PM
