Short throw Shifters
On the surface these would seem like a good idea. However, I see some "complaints" on the Internet about vibration, noise and diffuclty shifting into reverse.
What are the pros and cons for intalling one of these units. I see Barton as one brand commonly used. Does anyone have any expereince with these and is there any reason not to put one in on a daily driver?
I just had the MGW shifter installed @ two weeks ago. Worth it.....probably the sinlge best upgrade I've done to one of my vehicles in a long time. The complaint I've seen regarding the MGW is the stiffness of the shifter when it's brand new. After a couple hundred miles....it's loosening up just like they said it would. Reverse...it takes only slightly more effort than stock. The overall feel is great....much more notchy than the factory unit....which I found to be very rubbery. I have much more confidence that I'll get into the right gear when I'm rowing through them.
I haven't noticed any additional vibration.....no added heat...but I also did the extra heat shield.
I'm more than satisfied with my MGW....can't ever imagine going back to the stock shifter. My Boss is a daily / casual driver....not a dedicated track machine.
Wayne
Wayne
I have a steeda and I am VERY happy with it, no more noise in the shifter other then when I move it left to right in neutral, and thats just a small tap. Reverse IS a little harder but the drivability, shifting and WOT shifting WAAAAAAAAAAAY outweighs the TINY amount pressure I have to add, after the second day I dont even notice that I try any harder at this point. For as small as it was, outside of a tune this is the best money I have spent on this car.
Good Luck....I really think the lower shift unit that MGW developed really helps give a solid feel when shifting.
Wayne
My theory is that over 50% of the improvement from the MGW comes from the design of their shifter bracket. So adding the Barton post bracket is probably a good place to start.
I watched the video on the intall well into the evening last night. Much more interesting then watching crappy sitcoms!
Anyway, other than having no access to a lift (I do have jack stands) I should be able to handle this one.
Now, while I'm under the car maybe its time to consider putting in those electric cutouts..................
Exactly what he said. I used ramps on the front and jack stands on the rear. If all your doing is the bracket then it's easy. Socket wrench, 10" extension, and I believe a 10mm deep wall socket and you're good to go.
I've had the MGW shifter in the car for a week or so...and I really like it. it is very firm and 'notchy' but in a good way. local shop installed it in 1.5 hrs with a lift...was thinking of doing it myself but decided to have the shop do it...so I can't comment on ease of install.
thanks again everyone. If anyone is thinking about and MGW call now as they are backed up with about 50 orders for this particular shifter. Hopefully, this will not cause them to rush the product!
Anyway, it's about a month wait right now.
While I wait I think I'm going to stop by a local gas station shop where the mechanic has been pretty good to me. I'm going to see if he will let me use his lift - which I will pay him something for. I could have him do the install but by the time he watches the videos etc. I might as well do it myself with him as backup if he will go for it.
9/16/15 06:44 PM
