Oil Temperature sender location
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
I believe it's in the same spot as the oil pressure sensor. Ford Lists a Specific Sensor for the Boss and it's $390.00 vs the $40.00 For the Non Boss Sensor. It's also a 3 Wire Sensor Vs a One Wire Sensor. It's located on the Oil Filter Adapter. Not a 100% on This but my best guess at the moment. I checked Ford Parts Cataloging, Wiring Diagram and Shop Manual.
KC
KC
Oil Temp Sender
Thanks for the info.I have all my senders in place ready to install the gauge pod.I thought it would be a good idea to get everything hot and be certain there are no leaks.Went out for a 5mi warmup,got back and parked on drive on lift.Had some other work,went back a few hours later and there was a small puddle of oil under the oil filter.Pulled down the plastis cover to find one of the 3 1/8 pipe plugs in the glowshift adaptor weeping.Checked it and tightened it a little more and took another more spirited ride,12mi or so.Come back,now really leaking,oil actually on rear bumper!Still leaking from the same plug. That's it for me,I never thought much of the adaptor from the beginning.I'm removing it completely, so no gauges this weekend at Pocono.I have 3.5" aluminum roundstock so i'll just make an adaptor.It has to be better and more reliable than what I have.
Guy
Guy
Guy
Guy
