Oil capacity...
Oil capacity...
So, first oil change today, and hmmm...
Just out of curiosity, how much oil did yours take before showing up maxed on the dipstick? I know how much mine took, and it wasn't 8.5 quarts.
8 quarts put mine at the mid level on the stick. So we added another 1/2. The tech filled the new filter with oil before screwing it on; smart move I might add.
Yep I always Pre-oil the filter, myself. I used the K&N, which is quite a bit longer than the standard FoMoCo filter. I expected to use closer to 9 quarts, but 8 dead even took me to max fill.
Hmm, OK. Guess I will 4-wheel jack it up the next time. Been a while since I had a car I had to do that with, but there must have been a little left due to the front only jacking.
Thanks for the sanity check, boys :-)
all i know is that i didnt have time to change it myself when i wanted to do it so they charged me $99 because it slurped up so much synthetic! Bas-tards also left one of the bolts out of the under tray too.
