2012-2013 BOSS 302
OE Throttle body and cold air
Old Jul 1, 2025 | 09:44 AM
GB1164's Avatar
Hi All,
just wondering if OE throttle bodies and cold air systems are still available for a 2013 Boss 302.
thanks in advance. Btw, I’m new to this forum.
Old Jul 1, 2025 | 10:10 AM
05stangkc's Avatar
Welcome,
Are You Just Wanting To Replace a Stock Throttle Body on Car or Some Kind of Upgrade?? Factory Airbox is a Cold Air of Sorts as Well. Just Need a Bit More Info!
Thanks,
Kc
As Far as An Oem Throttle Body I Believe This Is The One. Put in VIN To Verify! {CLICK ON CHECK ANOTHER vehicle with vin}
https://www.fordpartsgiant.com/parts...=&filter=(5571)
Old Jul 1, 2025 | 12:18 PM
GB1164's Avatar
Just wanting to return the Boss to factory. Thank you for reaching out.
Old Jul 1, 2025 | 12:41 PM
05stangkc's Avatar
If You Want a List of Oem Part Numbers For Specific Items I Am Happy To Work Up a List. Just Pm A Vin So I Can Be Sure of Parts Accuracy! A Pic of Any NON-STOCK Items Would Be Great. Air Intake Parts are All Piece By Piece If Some Sort of Air Box Mods Have Been Done.
Example of Air Intake Break Down. Not Vin Checked!
https://www.fordpartsgiant.com/parts...l?filter=(5571)
KC
Also Love To Hear Your BOSS Story & Overall Pics of Car as Well!
Old Jul 3, 2025 | 07:34 AM
GB1164's Avatar
Hi KC,
Thank you for offering to pull together a list of parts, very kind. I do not have a Boss 302 yet, but I’m looking at several - all 2013. WAY over priced right now. There’s a Red 302 that has everything, but the prior owner changed out the cold air system including the throttle body.
1ZVBP8CU0D5236199
My understanding is the throttle bodies are still available, but some of the cold air “hoses” may be obsolete. Can you confirm that? Any thoughts on how to overcome the obsolete parts would be helpful too.
Thanks KC. Neil.
Old Jul 3, 2025 | 08:41 AM
05stangkc's Avatar
Finding Parts is My Specialty. Some Times There are Leftovers on Dealer Shelves That Can Be Had. A Piece By Piece can get Expensive. A Good Complete Used Setup Maybe The Way To Go as Well. If it is Out There I Am Good at Tracking Pieces Down. The Boss is Definitely a Premium Car and One That is Original and Had a Good Owner is The Way To Go. Rather pay Extra For a Cream Puff Vs One That Has Been Beat & Abused. They are Quite Prized By Owners and For Good Reason. They Are Special. The Right car Will Come Along with Patience.
Be Advised if it Has a Cold Air It {May} Also Have a Tune So Be Advised if So You Would Need To Get Tuner if Available. Also Always Make Sure They Have More Than One Key. Sometimes A Car Lot Will Get a Car With The My Key Set on Restricted Settings. If Car So Equipped. Car May Have Track Key as Well I Believe. Sorry I'm a Bit Rusty on The 10-14's I Specialized on The 05-09's Mostly back in The Day! I Know For Sure With One Key You HAve To get Dealer or Locksmith To Program More and That Gets Spendy!
If You Have a Vin on One You Are Hot to Go On Send it To Me and I Will Do Some Checking. Not Sure if All The Airbox Pieces Are The Same For Both Years and if Some of The Pieces are Same as GT. If You Don't Have a Vin I'm Sure I Can Conjure One Up as Most Online Sales List One for Carfax. But I Can Also Get a Little Backstory on Car History So an Actual Vin From You Would Be Best! I Can Also Check All Options That Came on Car.
I Totally Missed Vin! Okay I Can Work With That! Had One of My Insomnia Nights Again! Still Trying To get The Noodle Working!
Let Me Take a Look!
KC
Old Jul 3, 2025 | 09:02 AM
GB1164's Avatar
Let Me Take a Look!
KC
Thank you KC, very appreciated.
Old Jul 3, 2025 | 09:43 AM
05stangkc's Avatar
Here is All The Oem Listings. Looks Like Some is Available But Be Advised Cataloging Online Can Be Behind a part That Has Gone Obsolete. While The Boss Intake Manifold is Special. I'm Thinking a Lot of This Is Same as GT. As Far as T/B & Air Cleaner. Let Me See if I Can Pin Down Interchangability a Bit More! I Do See The Intake Hose Shows Not Available at The Moment!
Notice Symbols Such as Circle or Triangle Indicating Parts Which Come With Assemblies. May also Be Available Separate as Well!
Throttle Body BR3Z-9E926-B Replaced By BR3Z-9E926-C
https://www.fordpartsgiant.com/parts...tra2=&filter=()
Sound Tube BR3Z-6C646-B
T/B to A/C Hose CR3Z-9b659-B
Air Cleaner Assembly BR3Z-9600-C
Air Cleaner Intake Duct AR3Z-9A624-A
Hardware
HN2 Size M8
W520803-S439
HB3 Size M8x40MM
W500311-S437
HN1 M6x0.8-4.0
W520812-S439
HB1 M6x35MM
W505427-S307
File Type: pdf
File Type: pdf
Old Jul 3, 2025 | 10:57 AM
05stangkc's Avatar
Current Update for Op Via Email!
Just a Thought Is Car on a Lot and Perhaps The Original Owner Still Has Stock Parts?? Or Are You Dealing With Owner and He Tossed Items???
KC
Old Jul 3, 2025 | 11:23 PM
Wheatie's Avatar
FYI.... about the best resource for the 12-13 Boss is the "2012-13 Boss 302 owners group" on FB. Hope it is OK to promote that here.
Plenty of guys may have one to sell you, Half the Bosses have been modified.
Old Jul 4, 2025 | 09:08 AM
05stangkc's Avatar
Nothing Wrong With Promoting Those With The Hands On With These Great Models!
KC
David Anderson
Sterling Gray
Apr 4, 2025 04:21 PM
Trap
Jan 29, 2021 05:06 PM
2006GT1995
Apr 4, 2014 04:06 AM
MoisTang
Apr 30, 2012 07:06 PM
TJKII
V6 Performance Mods
Aug 27, 2006 03:18 PM
