2012-2013 BOSS 302
Limp mode, Engine Temp or Oil Temp
Old Jul 24, 2014 | 03:41 PM
JPC's Avatar
JPC
I know our Boss have a limp mode
..........I call it "having too much fun" mode
Anyways, who knows that the parameters are for the limp mode to be triggered?
Old Jul 24, 2014 | 08:23 PM
2006mach1's Avatar
On the 12's, engine coolant temp triggers limp mode, somewhere around 245-250 degrees I believe. And if you are reaching those temps, imagine what your oil temps are with the factory cooler! My oil was 270-275 degrees after the cooler when running 220 to 230 water temps.
Old Jul 25, 2014 | 08:38 AM
JPC's Avatar
JPC
I'd like to find out the engine coolant temp that triggers limp mode, anyone know?
Old Jul 26, 2014 | 06:57 PM
nota4re's Avatar
Hate to break it to you, but your car does not have a coolant temp sensor. Coolant temps are derived from Cylinder Head Temps (CHT), and there is no gauge for CHT.
Old Jul 26, 2014 | 10:16 PM
BaknBlk's Avatar
Actually in the Boss there is a cylinder head temp gauge.
Old Jul 27, 2014 | 11:58 AM
boss man's Avatar
More please.... are we talking 12 & 13. Location of sensor.
Old Jul 27, 2014 | 04:25 PM
BaknBlk's Avatar
It is part of the digital gauges in the 13 Boss 302. Either displays as a gauge or just a digital readout.
Little hot in Phoenix when I took this pic.
Old Jul 27, 2014 | 04:28 PM
P0 Corsa's Avatar
Kendall is correct at least for the 2012 engine. The coolant temp is synthysized from a sensor in the cylinder head although (as far as I know) the cylinder head temp is not reported. Perhaps it is on the buss and can be read by an instrument plugged into the OBD plug.
Well, there you go cyl head temp is available on the 2013 model.
Old Jul 27, 2014 | 05:33 PM
dmhines's Avatar
Holy Moly .. you sure your cooling fan is working?
Old Jul 28, 2014 | 03:14 PM
BaknBlk's Avatar
Yep, it was working....the inlet air temp wasn't helping at all.....but of course as they say, it's a dry heat.....!!
Old Jul 29, 2014 | 08:56 AM
killaz05's Avatar
You could always put it in engineering test mode by holding the reset and setup buttons while starting the car. I know in my base 2014 v6 I get a coolant temp reading according to the dash.
Fastnloud
Feb 15, 2016 05:21 PM
dblhelx
Oct 6, 2015 08:08 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Allen Hanback
Sep 14, 2015 04:37 PM
