Limp mode, Engine Temp or Oil Temp
I know our Boss have a limp mode
..........I call it "having too much fun" mode Anyways, who knows that the parameters are for the limp mode to be triggered? |
On the 12's, engine coolant temp triggers limp mode, somewhere around 245-250 degrees I believe. And if you are reaching those temps, imagine what your oil temps are with the factory cooler! My oil was 270-275 degrees after the cooler when running 220 to 230 water temps.
I'd like to find out the engine coolant temp that triggers limp mode, anyone know?
Hate to break it to you, but your car does not have a coolant temp sensor. :) Coolant temps are derived from Cylinder Head Temps (CHT), and there is no gauge for CHT.
Actually in the Boss there is a cylinder head temp gauge.
Originally Posted by BaknBlk
(Post 6833100)
1 Attachment(s)
It is part of the digital gauges in the 13 Boss 302. Either displays as a gauge or just a digital readout.
Little hot in Phoenix when I took this pic. |
Originally Posted by nota4re
(Post 6833041)
Well, there you go cyl head temp is available on the 2013 model. |
(Post 6833294)
Yep, it was working....the inlet air temp wasn't helping at all.....but of course as they say, it's a dry heat.....!!
You could always put it in engineering test mode by holding the reset and setup buttons while starting the car. I know in my base 2014 v6 I get a coolant temp reading according to the dash.
