2012-2013 BOSS 302
Hood vents for 2012
Old May 27, 2012 | 01:31 PM
JPC's Avatar
JPC
Hood vents for 2012
I know the 2013 Bosses have hood vents, and I don't have the budget for TR Hood, I was researching to ADD hood vents to my OEM hood.
...under the hood heat is bad at the track, and here in Texas we specialize in HEAT
I saw these I liked (long and thin LIKE the 2013's)
from Run Cool
http://www.hoodlouvers.com/products....5#productsside
Any one try these on other cars?
Any comments?
Old May 27, 2012 | 01:38 PM
dmn8rHD's Avatar
Interesting. Curious as to what people have to say about them
What were you thinking, mount them parallel to the power dome on the hood?
Old May 27, 2012 | 04:26 PM
JPC's Avatar
JPC
yes, similar to the location as seen on the 2013 hoods
Old May 27, 2012 | 05:28 PM
CCTking's Avatar
I think it would look pretty nice, if you do decide to install them do a write-up and review of results because i would definitely like a lil newer styling on the whip
Old May 27, 2012 | 05:47 PM
I don't see any 'under hood' moulding or accessories to direct water away from pouring on engine.
Old May 27, 2012 | 07:31 PM
2006mach1's Avatar
You can buy the 2013 hood louvers seperately from your Ford dealer. They will run you about $150 a piece. More money than the aluminum louvers but nicer IMO.
Old May 27, 2012 | 07:37 PM
ford20's Avatar
The only trouble is mounting them. The hood on the 2013 is recessed for the hood lovers which the 2012 hood is not and like Charlie said you still wouldn't have any water troughs to divert water from the engine
Old May 27, 2012 | 09:41 PM
CCTking's Avatar
Yea the water issue is big. Maybe custom fab? But then thats talkin money
Old May 27, 2012 | 11:21 PM
JPC's Avatar
JPC
I need to see/take pictures of the 2013 hood vents
Are there any notes in the 2013 Mustang owners manual about the hood vents and rain?
BTW, my Boss is in the garage during the nite so low chance of evening rain getting onto the motor
I need to see these vents up close for rain
http://www.hoodlouvers.com/questions.html
Old May 27, 2012 | 11:43 PM
cf6mech's Avatar
Jerry,.... I would wait and save up for the Tiger hood if I where you,... yah they may help a little venting some heat but no where near the Tiger hood in my opinion.....plus ur putting two gapping holes in the original hood, and if you have someone else install them the labor cost could be used towards the price of the tiger hood.
Old May 28, 2012 | 12:41 AM
JPC's Avatar
JPC
What's the price of a tiger hood/painted easy over $1400
Old May 28, 2012 | 06:54 AM
2006mach1's Avatar
I wash my engine bay all the time and never have an issue with water on or in the engine. And I use a power washer!
Old May 28, 2012 | 07:56 AM
5 DOT 0's Avatar
While adding vents will help dissipate the heat under the hood I don't think they will help with the overheating issue. I also looked at adding vents to my hood but I don't think there's an easy way to add them that still looks OEM. Best bet is to save up for an aftermarket hood and there are a couple of less expensive options other than the 302S hood. Here are photos I took of the new vents.
Old May 28, 2012 | 08:36 AM
mammothcar1's Avatar
Agreed.
By the time you find a body shop that will to cut, fabricate, fill, smooth, sand prep, and paint you'll be talking some big bucks. Plus, if they screw it up, you're out a stock hood for your car.
If you need the extra cooling for the track, save up your money and go for the tiger racing fiberglass version. The finish is very good as is. You could just be hard core and leave it unpainted and run it as is.
It's an easy swap with an extra set of hands if you need to go back to the stock hood as a daily driver or car show.
Old May 28, 2012 | 01:14 PM
boss man's Avatar
Are the openings on the 2013 hood only about 1/4 of what apears on the top of the hood? The openings look to be off to the side only??
Old May 28, 2012 | 07:26 PM
5 DOT 0's Avatar
The vents are fully open but the material under the hood covers a lot of it. You can easily cut it out if you're having overheating problems but I don't think it's going to help much.
May 3, 2026 05:42 AM
yabutt
Oct 23, 2015 01:05 PM
boz
Oct 1, 2015 04:47 PM
TerryD
Sep 28, 2015 11:48 AM
samjluck
Sep 17, 2015 10:24 PM
