2012-2013 BOSS 302
Gauge display goofiness
Old Mar 6, 2013 | 09:03 AM
mattlqx's Avatar
Came out to my car this morning and was greeted by this...
At least the box matches the color of my car.
Old Mar 6, 2013 | 10:13 AM
SBYBoss's Avatar
I saw someone else post on one of the other forums about this recently. I don't recall what the fix was but it may have been a loose wire or cut insulation shorting out - sorry I don't recall.
If I happen across the other post again I'll come back here and give you a link.
Old Mar 6, 2013 | 12:31 PM
stupidgenius36's Avatar
Just Plain Rude!
Odd...So is it still like that, or did it go away?
Old Mar 6, 2013 | 04:02 PM
Sammykjr1's Avatar
Let it sit for 15mins (after removing the key). Start it again. Report it to your dealer to ensure they document it before warranty runs out. Hope it works!
Old Mar 6, 2013 | 07:23 PM
SBYBoss's Avatar
It's always a good idea to unhook the battery, re-connect and see if the problem persists.
Old Mar 6, 2013 | 09:24 PM
Brandon302's Avatar
The old, turn it off and on again fix, usually works.
Old Mar 8, 2013 | 12:15 AM
mattlqx's Avatar
Ignition cycle didn't fix it, but after I got out of work, it worked fine when I started it back up for the drive home. Fluke hopefully?
Old Jun 27, 2013 | 06:53 AM
TH3HULK's Avatar
Any other news on this? It just happened to me this morning. I also have a GHIG BOSS, maybe the display likes matching the exterior color from time to time...
Old Jun 27, 2013 | 10:55 AM
Brandon302's Avatar
As silly as it sounds it might make sense to bring it by the dealer, maybe firmware needs updating and they weren't aware of the issue.
Old Jun 27, 2013 | 11:54 AM
ConeBoss's Avatar
That definitely seems like a dealer should take a look type of issue. Even if they can't re-pro it will be on file that you had the problem so if it gets worse there will be a documented history to back you up.
Old Jul 4, 2013 | 10:39 AM
mattlqx's Avatar
I never had an issue except for the one time leading to this post. It's been solid since.
Old Jul 4, 2013 | 02:22 PM
denlem's Avatar
I thought maybe it was a Tetris option to play at red lights!
trackpack13gt
Jul 25, 2017 05:29 PM
K.A.I.N
Sep 25, 2015 03:27 PM
