Dyno Numbers
Guss, you guys provided the CAI for this
anyway, the tune was off the dyno we were on here was not updated and the tune on the car was based off a GT tune which i didn't know at the time had the fuel cut off set at 7200 rpm. the tuner was also unable to control fuel after 6700 or so where it went rich, still nice gains for headers, catted X, and a steeda CAI.
EDIT: i just realized i haven't uploaded the dyno pull with all the mods on, the second vid is without the headers and x and with the sct tune for a Gt rather than the boss.
stock dyno pull, they didn't go to redline and this is on a mustang dyno.
dyno pull with mods
i have the new tune that i mentioned in the other threads so once i get it on the dyno ill update. its so **** hot here now im not sure what to expect, texas is on like day eleventy million of 105 plus temps
dyno pull with mods
Thanks Gus. I wonder if there is a sort of unfair advantage to an open element CAI run with the hood up? Would the gain be as big with the hood shut like the car is when driving?
thanks for the info.
I think it has more to do with cooling than anything else.
Having the hood closed only simulates one thing, sitting in traffic and not moving.
When you are moving and under wide open throttle, I guarantee you'll be going faster than 40 miles per hour
Thanks for the feedback Gus. I see what you are saying. I'm not sure I totally believe that is true. I do like your design. The bellmouth feeding the tube seems like a good idea. Thanks.
Here is mine...68*, 18% humidity
Weather cooled off a bit here in AZ this week, took her in to get a baseline dyno.
2550 miles on the car now.
Mods: K&N filter, Roush Mufflers, Open sidepipes.
Run 2 (Red Line)is the K&N.
Run 4 (Blue Line) is the Stock Paper Filter.
Not much difference, K&N might have a slight advantage from 5000rpm to 6800 or so.
![Name: bsFvx.png
Size: 68.1 KB](https://themustangsource.com/forums/attachments/f813/216588d1683056405-dyno-numbers-bsfvx.png)
No more (power) mods for me!
April 2012 Dyno Results from Rizza Racing:
SAE corrected values of 385.5hp / 347.11tq - No engine mods (even OEM air filter). Disks removed from side exhaust.
#40
