2012-2013 BOSS 302
Check for this defect!
Old Jun 2, 2011 | 05:12 PM
4pipes's Avatar
Today I decided to change all my shocks to setting 5, in anticipation of my track day next week. The left rear shock valve was defective. The red portion was not swaged into the top of the shock all the way and was loose.
I've seen this reported before.
Went to the dealer, they said it's a warehouse item and they'll install the replacement next Tuesday....just in time!
BTW, list for the shock is $550.
Old Jun 2, 2011 | 05:21 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
Old Jun 2, 2011 | 06:52 PM
2012YellowBoss's Avatar
Wow, that should not have happened. I can understand a loose piece of trim here and there on thousands of car and trucks passing down the lines, I don't condemn all union workers for that. Nothing is perfect and certainly not massed produced things but that part should have been inspected before it left the vendor, especially if it is so clear to the naked eye.
Old Jun 2, 2011 | 08:52 PM
Jason29's Avatar
This is good information. Anyway you could take a picture of it for reference?
Thanks!
Jason
Old Jun 2, 2011 | 08:56 PM
4pipes's Avatar
Too much trouble. Just imagine the red adjustment section not seated into the top of the shock.
Old Jun 2, 2011 | 09:09 PM
Fenderaddict2's Avatar
Just picked my Boss up again from dealer where it sat for 3 days while they searched for a rattle I could hear behind passenger dash. They had to tighten the shock mounts and the fender mounts all of which were loose. Car had the rattle the first day. Scary.
Old Jun 2, 2011 | 09:31 PM
Jason29's Avatar
I noticed when I adjusted mine earlier today, the red adjustment screw portion only seemed to rise up a bit on all the shocks. This was the first time I adjusted them, so I wasn't sure what to expect. Would seem normal for the adjustment screw to have some play though. The rest of the red top was solid.
Old Jun 2, 2011 | 09:37 PM
4pipes's Avatar
They should feel INTEGRAL to the shock. No up and down movement.
Old Jun 2, 2011 | 10:09 PM
phytrpilot's Avatar
Need to report this to FCS; via Deysha if needed.
Old Jun 2, 2011 | 11:40 PM
4pipes's Avatar
These are, apparently, the shocks we have:
http://www.tokicoperformanceshocks.c...a_details.aspx
I looked at the literature to see if it was ok to rotate the adjustment valve through more than 360 degrees. There is no mention of rotation limits in their literature or Fords.
Old Jun 3, 2011 | 04:08 AM
Jason29's Avatar
Is anyone else able to move the adjustment screw 360 degrees or more? Or does your screw stop at one rotation?
Old Jun 3, 2011 | 06:55 AM
89Turd's Avatar
Mine spins freely.
Old Jun 3, 2011 | 09:59 AM
fuhrius's Avatar
did you see where they came from?
Tokico has a plant in Fukushima. they have other plants too...but there may be a correlation.
Old Jun 3, 2011 | 12:47 PM
Bueller's Avatar
This is a great thread.
I just took a look at the Tokico website from the link above, and it says, "Illumina uses TOKICO’s sophisticated multi-stage, variable-aperture piston and valve system, combined with a five-position bypass shutter-valve. A crisp shutter-valve detent allows quick, sure selection of the five settings."
A detent is a click or notch. An adjuster that spins freely does not sound right. I will check mine when I get home tonight.
B -
Old Jun 3, 2011 | 03:11 PM
12C/OBoss's Avatar
My car #127 delivered in March has had them loose from day 1... I reported it here as the adjuster spins more than 360 degrees. I will search for my thread
Old Jun 3, 2011 | 03:24 PM
12C/OBoss's Avatar
https://themustangsource.com/f813/3r...5/#post6034620
Old Jun 3, 2011 | 03:52 PM
Jason29's Avatar
All 4 of my shocks adjuster's turn freely more than 360 degrees. Are you sure your rear ones stopped? Anyone else have theirs turn freely or stop? I placed a call and left a voicemail for technical support at the shock company to see what they say.
Old Jun 3, 2011 | 03:59 PM
4pipes's Avatar
Picture of defective adjuster
Here's a pic of the faulty adjuster. You can clearly see that the red adjustment assembly has separated from the top of the shock. I don't know if it affects the adjustment, I'm getting the shock replaced next week.
I also don't know if the adjusters are supposed to rotate more than 360 degrees......I didn't test for that.
https://themustangsource.com/gallery...ge.php?i=31839
Old Jun 5, 2011 | 11:20 AM
MJockey's Avatar
Mine turn freely with a slight click at the number. I check and none have a separated adjustment assembly like Dave's.
Mar 30, 2021 09:29 AM
PonyMuscletang13
Sep 29, 2015 09:40 AM
oldnjguy
Sep 10, 2015 02:39 PM
