Can't keep side pipe's tight
Ever since I removed the discs I've had issue's with the bolts just under the rocker panel. If I get them too tight then they buzz in the door panels, If I leave them a bit looser then they work ok for a bit, but then get loose and buzz the same way. I've tried two different loc-tite products and am still unable to keep it consistently tight.
I detest the buzzing in the door panels!
Is there a specific torque # anyone's found to work well or anything else...
You can even go with a little less but not too much about 3/8. If you have trouble getting it lined up in a good position, loosen the long bolt on the adjustment band and you can rotate the pipe better. My came from the factory a little off and this fixed it.
9/24/15 08:15 PM
