2012-2013 BOSS 302
Can't keep side pipe's tight
Old Nov 21, 2011 | 01:39 PM
DA712's Avatar
Ever since I removed the discs I've had issue's with the bolts just under the rocker panel. If I get them too tight then they buzz in the door panels, If I leave them a bit looser then they work ok for a bit, but then get loose and buzz the same way. I've tried two different loc-tite products and am still unable to keep it consistently tight.
I detest the buzzing in the door panels!
Is there a specific torque # anyone's found to work well or anything else...
Old Nov 21, 2011 | 01:48 PM
phytrpilot's Avatar
Dave, make sure you have about 1/2" clearance between the side pipes and floorpan. I didn't leave enough clearance first time around and had a similar problem. There is a lot of "play" at the two bolt flange so ensure you come off at the correct angle.
Old Nov 21, 2011 | 01:53 PM
NCETRY's Avatar
Had the same problem and it turned out to be clearance problem with the floor pan near where the side pipes bolt up to the exhaust.
Old Nov 21, 2011 | 02:01 PM
DA712's Avatar
Ah, Ok, will ck that. Thanks!!
Old Nov 21, 2011 | 02:52 PM
MyStang2010GB's Avatar
Same issue and same fix
Old Nov 22, 2011 | 04:13 PM
2012YellowBoss's Avatar
You can even go with a little less but not too much about 3/8. If you have trouble getting it lined up in a good position, loosen the long bolt on the adjustment band and you can rotate the pipe better. My came from the factory a little off and this fixed it.
Mar 30, 2021 09:29 AM
Fedupdave42169
Sep 30, 2015 08:45 PM
NC14GT
Sep 27, 2015 05:35 PM
Sep 24, 2015 08:15 PM
