2012-2013 BOSS 302
Can these two issues be fixed?
Old May 1, 2016 | 09:41 PM
Dayve's Avatar
So I know there has been a lot of talk about the high RPM shifting issue and wheel hop. I hate them both. I have not done a single mod yet, but thinking about the MGW shifter and Blowfish Bracket. Have updates been done so all the kinks are worked out when installed on a Boss? I am looking for an inexpensive fix for the wheel hop too, that does can be done with bolt on parts. I do not want any drilling or welding. I will probably complete the mods with an aluminum one piece drive shaft. Been thinking long and hard about these things for going on four years, time to get er done. Any comments on brands or install shop in San Diego area?
Dave
Old May 2, 2016 | 12:31 PM
fking1's Avatar
MGW will help the lockout and Blowfish not need.
To absolutely solve lockout replace the clutch with a Spec or McLeod.
Both these worked for me.
Old May 2, 2016 | 06:55 PM
redonblackpony's Avatar
Hi speed/rpm lockout is caused mostly by the stock clutch. Change to a racing clutch and the problem will be solved.
I have McLeod RST and I've had no issues at the race track
Old May 2, 2016 | 07:34 PM
fking1's Avatar
I have a Spec2+ clutch and with the MGW no lockout and great for autocrossing and drag racing.
Old May 3, 2016 | 04:56 AM
Gabe's Avatar
A new shifter like the awesome new MGW Race Spec will help a lot.
Start there and see if you still need to do anything else.
I put in a Barton with a new Barton shifter bracket and removed the clutch "helper" spring from the clutch pedal and my issues are gone
As far as the wheel hop, start with some new rear lower control arms.
Most of the time that'll fix the hop and nothing else is needed.
Old May 3, 2016 | 07:13 AM
fking1's Avatar
Barton Shifter with the bracket & Blowfish did not cure lockout for me. It worked off & on ,but, not always.
As I noted above the MGW & Spec 2+ fixed it always.
Old May 4, 2016 | 03:25 PM
boss man's Avatar
If you have problems finding a gear or notchy feeling at just fun driving. Then I would recommend the blowfish bracket or the MGW Race spec shifter. The BF bracket is easier to install. It also keeps the car stock / except the bracket if that maters
If you have lockout at high RPM or the clutch pedal sticking to the floor then its your clutch that needs to be replaced.
Do not buy any of the stiffer bushings that CLAIM to reduce the shifting problems. I don't want to name vendors.
If you go the clutch route. Stay far away from the stock clutch. It can not handle the high RPM's.
Good Luck in your choice to correct the problem your having.
Old May 4, 2016 | 05:51 PM
Dayve's Avatar
I honestly do not think I have ever missed a gear. My pedal has never stayed on the floor, but, I do have the lock out at high RPM's. That and wheel hop, need a cure for both that does not involve drilling or welding.
Old May 4, 2016 | 07:23 PM
fking1's Avatar
As stated before the cure for these 2 problems are an MGW and clutch, either Spec or McLeod.
Old May 5, 2016 | 06:07 PM
Dayve's Avatar
Are there different models of the MGW or is it just one, that fits the 2013 Mustang or Boss specific?
Old May 5, 2016 | 07:39 PM
fking1's Avatar
Their Race Spec Boss Specific is the one you want.
Go to the MGW web-site.
Old May 9, 2016 | 06:42 PM
ford20's Avatar
If you can wait a bit, I have a pair of BMR LCA's that I can sell you once I get my car back from JPC Racing. They took care a large majority of my wheel hop issues.
Old May 10, 2016 | 06:23 PM
Dayve's Avatar
I was actually looking at the 302S LCA's. I like the fact that they were standard on the Boss S. Pretty expensive though, but it would be my first mod.
Dave
ThatStangGuy
May 14, 2016 05:44 PM
AKeith
May 14, 2016 02:47 PM
John Wysocky Sr.
Apr 27, 2016 05:03 PM
odiaz
Apr 26, 2016 11:27 PM
