2012-2013 BOSS 302
BOSS 302S Specifications
Old Oct 12, 2011 | 08:00 PM
2012-LS134's Avatar
Some interesting/useful tech info from the 302S owners manual...oil filter, fluid change intervals, mufflers (GT500 mufflers), 100 octane fuel requirement
Section 1 Ford Racing Boss 302S Specifications
Engine
5.0L Ford Racing Motorsport Engine, based on 2012 Mustang Boss 302 engine
Ford Racing Oil Pan, M-6675-M50BR
Ford Racing Oil Filter, CM-6731-FL820
Engine Oil: Motorcraft 5W50 full synthetic or equivalent
Setrab ProLine Engine oil cooler
Upgraded electrical connectors
FR intake badge
Boss 302 fuel system
Upgraded cooling system
Driveline
6 speed transmission with Dual Disc Clutch
Torsen T2R Diff
3.73 gears
Chassis
Front: coil over dampers
Front lower control arms with delrin bushing kit
FR adjustable front anti-roll bar
Caster/Camber plates
Rear: coil over dampers
Rear tubular lower control arms with spherical bearings
FR anti-roll bar FR adjustable panhard bar
EPAS with unique Ford Racing calibration
FIA Spec 6 point roll cage
FR1 Muffler
Electrical
Lightened FR wiring harness
AMB Transponder
Switch plate – Start/ignition, aux switches
Interior
AIM MXL data acquisition system with GPS
Recaro HANS Pro Racer seat
Fire system with 2 nozzles
Quick release racing steering wheel
Window net
Safety system triangle nets
6 point racing harness
Master cut off switch
Exterior
FR front splitter
Rear adjustable CF wing
Unique Carbon hood with air extractors
Hood pins
19X9″ and 19x10" wheels
Boss 302S graphics package
F/R tow hooks
Brakes
Brembo race 4 piston front brake system
2 piece 14″ front rotors
PFC racing pads 4
Carbon Fiber Brake duct kit
Stainless steel brake lines
FR brake booster assembly
Unique FR ABS calibration
Section 7 Safety Equipment/Maintenance/Part numbers
Maintenance
Engine: M-6007-M50BR
The engine is a production 2012 Boss 302 engine with the exception of the oil pan and engine harness…all service
information and parts pertaining to a production 2012 Boss 302 engine applies.
Oil pan: M-6675-M50BR
Engine Wiring harness
This harness is a production 5.0L Boss harness that is modified by Precision Race Services (PRS). The four camshaft
VCT phasers (cam covers, front of engine), 4 camshaft position sensors (cylinder head, rear of engine) and the
crankshaft position sensor (RH rear of engine) connection are modified by Precision Race Services.
Please contact PRS for spares or service parts:
16749 Dixie Highway Suite 9
Davisburg, MI 48350
(248) 634-4010 office
(248) 634-4014 fax
Fuel
Sunoco GT 260 www.sunocoinc.com/Site/Consumer/RaceFuels/UnleadedFuels/Sunoco260GT.htm
(WARNING! USING A LOWER OCTANE FUEL WILL CAUSE PERMANENT DAMAGE TO THE ENGINE)
Fuel Filter
The Fuel filter is integral to the fuel tank and non-serviceable.
Engine Oil
Motorcraft 5W-50 Full Synthetic XO-5W50-QGT
Replace every 4 hours on-track usage
The recommended oil level is the bottom of the crosshatching of the dipstick (approximately 14 quarts)
Oil Filter
Ford Racing M-6731-FL1A (case of 12) or CM6731-FL820 (individual)
Replace every 4 hours of on-track usage
Regularly check the catch can for oil located on the passenger side rear of the engine compartment.
Capacity: 13 Quarts
Engine Coolant
Motorcraft Premium Gold VC-7B
50/50 Mix Ratio
Change annually and follow guidelines on container for freeze protection
Use only distilled water! 17
Transmission Fluid
XT-2-QDX Mercon ATF
Capacity: 3.46L
Clutch: CR3V-7B546-AA 2012 GT500 Dual Disc
Note refer to factory service manual when servicing.
Differential Oil
75W140 Synthetic Gear Lube Motorcraft XY-75W140-QL
Capacity: Fill to bottom of filler hole.
Brake Fluid
Use only High Performance DOT3 PM-1-C
Bleed brakes after each session. Replace Fluid after each event
Wheel/Tires
Front; Pirelli P Zero 255/40ZR19
Rear; Pirelli P Zero 285/35ZR19
Wheel torque: 95 ft-lbs
For World Challenge competition the following wheel and tires are required….
Wheels 18x10" Ford Racing M-1007-R1810 (requires unique lug nuts) Allstar-ALL44102, LUG NUTS 1/2-20, STEEL 10PK
Tires: Pirelli 305/45-18 P Zero Race Slick
Air Filter
FA1897-Motorcraft
Replace after every 12 hours of usage
Spark Plugs
BR3E-12405-DA (Heat Range 1) or M-12405-M50 (Heat range 0)
SP519-Motorcraft
GAP= 0.04 (1.0 mm)
Replace after every 6 hours of usage
Fuel Pressure,
55±2 psi gauge, fuel pump on and engine off
Part number listing
Button, Start Engine M-11572-GT
Shock Mount, Rear M-18197-A
Booster, Race Brake M-2005-R
Pad, Rear Brake Kit M-2200-R
Differential M-4204-T31H
Kit, Ring & Pinion Install M-4210-B1
Crossbrace, Trans Cooler Air Scoop M-5025-MBR
Muffler, SVT Kit M-5230-MGTCA1
Bar, Front Anti Roll M-5490-A
Bar, Rear Anti Roll M-5490-A
Adaptor, Remote Oil Filter (On Engine Block) M-6881-M50
Shifter Assembly M-7210-B
Lever, Shift M-7213-J
Radiator Assembly M-8005-MGT
GT500 Transmission AR3V-7003-BC
Old Oct 13, 2011 | 02:13 AM
Berol's Avatar
Good to see a little more clarification on the Ford Racing 820 oil filter- looks like it should be just fine. I think I'll be ordering a few to try them out.
Old Oct 13, 2011 | 06:03 AM
Jimmy Pribble's Avatar
I'm more of a 302R man myself, but hey, I'll take what I can get. Seriously, thanks for the excellent information.
Any word on spring rates?
Jimmy
Old Oct 13, 2011 | 08:55 AM
ApexCars's Avatar
I'd like to get a part number or info on where to get the oil catch can they are using.
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
MustangConvert11
Sep 30, 2015 08:01 PM
GeoWett
Sep 30, 2015 06:40 AM
