BOSS 302 vs GTR Nelson Ledges vid
I apologize if there exists a video area, I looked and couldn't find it. Any how, new member here. Picked up a '12 boss 302 and headed up to Nelson Ledges this weekend....This GTR was chasing me the whole time. Real impressed with how the boss performed. There are about 7 more vids on you tube under the name benbucks ... he was my new friend filming in the GTR.
cut and paste I guess?
Once again, sorry it this is the wrong place to post...
Thanks guys! No mods, strickly stock...first time at the track with this car. I know the track pretty well. I was very impressed with the car ability. He really could only catch me by out braking me at the last turn before the front straight.
I was running 35 psi cold and 41 hot...fronts on 4 and rears on 2....yep that track is rough...not very forgiving.
What tire pressure should I be running hot for best grip?
Rears at 2...I need to try that....
Upgrade brake fluid..... I use Motul 600
Upgrade tranny and rear end fluid..... I went with RedLine @ 20k miles
Remove rear dust shields, for better rear cooling...
I run a Carbotech RP2 front pad and brake ducting....I like brake deep and hard :-)
And what would be the optimum hot pressure on the tires? I had a fairly consistent temperature across the tread width...maybe 41 hot is it.
Thanks for the input.
Brake ducts will help with the pads until they run out. I would do HP+ pads or something similar if you decide to drive on the street. I have HPS's currently and they are good but could be better for the track. I would say about 40 psi is good.
I am running stock Pirelli P-zero's. I have not run at Nelson with Ford Racing springs as I just put them on in September and have not run Nelson since then. With factory suspension I believe my fastest lap was around 1:18. I had G-tech info but I must have deleted it. I hope to get down there by the begining of June.
Evil_Capri
9/11/15 08:39 AM
