2012-2013 BOSS 302
BOSS 302 vs GTR Nelson Ledges vid
Old Apr 29, 2013 | 09:03 AM
billiardbrawler's Avatar
I apologize if there exists a video area, I looked and couldn't find it. Any how, new member here. Picked up a '12 boss 302 and headed up to Nelson Ledges this weekend....This GTR was chasing me the whole time. Real impressed with how the boss performed. There are about 7 more vids on you tube under the name benbucks ... he was my new friend filming in the GTR.
cut and paste I guess?
Once again, sorry it this is the wrong place to post...
Old Apr 29, 2013 | 09:55 AM
JPC's Avatar
JPC
perfect place to post :-)
Old Apr 29, 2013 | 09:58 AM
JPC's Avatar
JPC
any mods to your 2012 Boss?
Looked good....I love when our Bosses are competitive against 2x and 3x priced cars :-)
Old Apr 29, 2013 | 10:03 AM
ConeBoss's Avatar
That's a nice video...good job fending off Godzilla. That track surface looks a little rough too.
Old Apr 29, 2013 | 10:27 AM
Thanks guys! No mods, strickly stock...first time at the track with this car. I know the track pretty well. I was very impressed with the car ability. He really could only catch me by out braking me at the last turn before the front straight.
I was running 35 psi cold and 41 hot...fronts on 4 and rears on 2....yep that track is rough...not very forgiving.
What tire pressure should I be running hot for best grip?
Old Apr 29, 2013 | 10:43 AM
JPC's Avatar
JPC
Rears at 2...I need to try that....
Upgrade brake fluid..... I use Motul 600
Upgrade tranny and rear end fluid..... I went with RedLine @ 20k miles
Remove rear dust shields, for better rear cooling...
I run a Carbotech RP2 front pad and brake ducting....I like brake deep and hard :-)
Old Apr 29, 2013 | 10:53 AM
Thanks for the advise...I brake hard too...these brakes aren't the greatest. What is going to be a better replacement tire once these are gone?
And what would be the optimum hot pressure on the tires? I had a fairly consistent temperature across the tread width...maybe 41 hot is it.
Thanks for the input.
Old Apr 29, 2013 | 10:55 AM
rears on 2 because I was too lazy to figure out where the adjustment was....
Old Apr 29, 2013 | 04:15 PM
Brandon302's Avatar
Brake ducts will help with the pads until they run out. I would do HP+ pads or something similar if you decide to drive on the street. I have HPS's currently and they are good but could be better for the track. I would say about 40 psi is good.
Old Apr 29, 2013 | 06:46 PM
2006mach1's Avatar
Nelson Ledges is a rough track! I still try to make it there a couple of times a year though. Cheap fun.
Old Apr 29, 2013 | 07:25 PM
Number23's Avatar
Wow, that track makes Summit Point look like Yas Marina Circuit
Old Apr 30, 2013 | 08:47 AM
Yeah, Nelsons is rough....Looks like your car is set up quite well!...What kind of times are you turning in there?..What tires are you running?
Old May 1, 2013 | 10:46 AM
2006mach1's Avatar
I am running stock Pirelli P-zero's. I have not run at Nelson with Ford Racing springs as I just put them on in September and have not run Nelson since then. With factory suspension I believe my fastest lap was around 1:18. I had G-tech info but I must have deleted it. I hope to get down there by the begining of June.
Old May 2, 2013 | 03:49 PM
racered302's Avatar
An easy way to get to the rear shocks is to fold the back seat down, they are right there.
exgto
2012-2013 BOSS 302
Oct 7, 2015 01:47 PM
Evil_Capri
Sep 11, 2015 08:39 AM
