Vendor Showcase Forum for Vendors to display their products and specials
Ny-Trex Wet Nitrous system V-6 or V8 on Special
Old 11/26/10, 02:15 PM
Xplosive Performance's Avatar
Black Friday WEEKEND Special
Ny-trex is proud to offer the all new EFI 6 or 8 cylinder wet nitrous systems. Ny-Trex EFI wet nitrous systems use only the highest quality materials and components to produce the best performing, best looking and most
reliable wet system around.
Ny-Trex systems have been throughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible.
Complete Systems Include:
10 lb Wet-Black powder coated bottle
Chrome Hi-Flo 660 bottle valve with gauge port
Braided stainless N2O feed line w/Tefl on core
22”x-3 braided stainless nozzle lines, 1 blue, 1 red
T-Rex Nozzle* & adapter (up to 300+HP)
Adjustable HP jetting
15A WOT micro switch
Quick-Clamp stainless bottle brackets
Mounting hardware, brackets, bolts, screws, clamps, ties
Electrical components, wire connectors, relays, switches
Drill & tap, fittings, sealant
Hot-Shot N2O & fuel valves
Lifetime warranty on solenoids
Special Features
Exclusive T-Rex Nozzle* with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering only 35 HP.
Nozzle has unique faceted spray tip to pass air around the nozzle without disrupting the spray pattern.
T-Rex is the highest fl owing nozzle available with .110 fuel and nitrous passages that can deliver over 300 hp with a single nozzle.
Flow matched fittings allow for the use of any style flare jets that are currently used in the industry.
Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts.
Plungers are made of high grade alloy with greater tolerances to prevent sticking. The N2O seal is Tefl on and a special Viton seal is used for fuel.
Dual Taper Jets provide a consistent fl ow of nitrous and fuel and come in a large array of sizes.
Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Tefl on sealant and easy install Quick-Guide.
MSRP $812.80
NOW
$550.95
  • Call toll free/PM/order online
mlcinema
10/7/15 10:05 AM
10/2/15 01:00 PM
mx5jhb
9/30/15 04:44 PM
Quick Reply: Ny-Trex Wet Nitrous system V-6 or V8 on Special
