Ny-Trex Wet Nitrous system V-6 or V8 on Special
Black Friday WEEKEND Special Ny-trex is proud to offer the all new EFI 6 or 8 cylinder wet nitrous systems. Ny-Trex EFI wet nitrous systems use only the highest quality materials and components to produce the best performing, best looking and most reliable wet system around. Ny-Trex systems have been throughly dyno-tested on numerous vehicles to ensure the most safe and reliable performance possible. Complete Systems Include: 10 lb Wet-Black powder coated bottle Chrome Hi-Flo 660 bottle valve with gauge port Braided stainless N2O feed line w/Tefl on core 22”x-3 braided stainless nozzle lines, 1 blue, 1 red T-Rex Nozzle* & adapter (up to 300+HP) Adjustable HP jetting 15A WOT micro switch Quick-Clamp stainless bottle brackets Mounting hardware, brackets, bolts, screws, clamps, ties Electrical components, wire connectors, relays, switches Drill & tap, fittings, sealant Hot-Shot N2O & fuel valves Lifetime warranty on solenoids Special Features Exclusive T-Rex Nozzle* with true-blend spray bowl delivers a swirl cone plume at a 110o angle to center the throttle body for an even blend. Flows up to 300+HP yet works great delivering only 35 HP. Nozzle has unique faceted spray tip to pass air around the nozzle without disrupting the spray pattern. T-Rex is the highest fl owing nozzle available with .110 fuel and nitrous passages that can deliver over 300 hp with a single nozzle. Flow matched fittings allow for the use of any style flare jets that are currently used in the industry. Solenoid valves are made with Volt-Trap coils for stronger, more effi cient power, allows for larger orifice, more flow and works with as low as 9 volts. Plungers are made of high grade alloy with greater tolerances to prevent sticking. The N2O seal is Tefl on and a special Viton seal is used for fuel. Dual Taper Jets provide a consistent fl ow of nitrous and fuel and come in a large array of sizes. Easy install components such as well nuts to install bottle topside, drill bit and tap for fuel connection, Tefl on sealant and easy install Quick-Guide. MSRP $812.80 NOW $550.95
