Now Available 01 Bullitt Upholstery!!
TMI has release Bullitt upholstery for 1999-2004 Mustangs. This will fit Bullitts and all other 1999-2004 Mustangs. You MUST use TMIs matching Bullitt seat foam with TMI Bullitt Upholstery.
C = Dark Charcoal
W = Oxford White
Y = Medium Graphite
P= Medium Parchment
Dark Charcoal (Original Color)
U54(color)1L: 99-04 2001 BULLITT SEATS FRONT BUCKETS (color) UPHOLSTERY – LEATHER $649.55
U54(color)5L: 99-04 COUPE 2001 BULLITT SEATS FULL SET (color) UPHOLSTERY – LEATHER $899.55
U54(color)6L: 99-04 CV 2001 BULLITT SEATS FULL SET (color) UPHOLSTERY – LEATHER $899.55
U54(color)1V: 99-04 2001 BULLITT SEATS FRONT BUCKETS (color) UPHOLSTERY – VINYL $349.55
U54(color)5V: 99-04 COUPE 2001 BULLITT SEATS FULL SET (color) UPHOLSTERY – VINYL $449.55
U54(color)6V: 99-04 CV 2001 BULLITT SEATS FULL SET (color) UPHOLSTERY – VINYL $449.55
SF26: 2001 BULLITT SEAT FOAM - ONLY USE WITH TMI UPHOLSTERY $149.55
Dark Charcoal w/ Titanium Inserts
Contact me Steve@cjponyparts.com or 1-800-888-6473 ext 143 to place your order's NOW!!
- Replacement upholstery for the 2001 Bullitt
- Originally only available in Dark Charcoal
- TMI has built the seats with even more side bolster support than the original Bullitt seats
- The center section is perforated like original
- MUST use TMI’s new Bullitt seat foam for the front seats, SF26
- You CANNOT reuse your original bucket seat foam
- The additional bolster support built into the seat upholstery and foam WILL NOT allow the upholstery to be used on original Bullitt seat foam
- Will work on all 99-04 V6 and GTs when used with TMI’s Bullitt seat foam, SF26
- Available in leather and vinyl
- Leather seats have a leather seating surface with vinyl back and sides, like original
- Vinyl was not an original option
- Includes new headrest upholstery
- Ford originally glued the rear seat upholstery to the rear seat foam
- Rear seat upholstery requires the old upholstery to be ‘skinned’ off of the original seat foam
- Includes an attachment kit for rear seat upholstery
C = Dark Charcoal
W = Oxford White
Y = Medium Graphite
P= Medium Parchment
- MUST be used on 99-04 seats when installing TMI’s Bullitt seat upholstery
- Sold individual, TWO REQUIRED to complete both front bucket seats
- Options: Custom Insert Color (You supply color code): +$50.00
- Special Order's can be placed for other colors
