Vendor Showcase Forum for Vendors to display their products and specials
It's HERE! Elite Series Sequential Foglight for 2018+ Ford Mustang | Diode Dynamics
Old 7/29/21, 01:03 PM
Supporting Vendor
Diode Dynamics's Avatar
Diode Dynamics is excited to introduce the Elite Series Combination Lamps for the 2018+ Mustang!
These lamps are a direct replacement for the 2018-2021 Ford Mustang's factory combination fog lamp housings, but provide greater functionality, maximum output, and a unique appearance. Designed for perfect fitment, these combination fog lamps illuminate in a cool white for your parking lights and DRL, and add a sequential turn signal as well as a modern startup sequence. They feature a gloss black bezel finish that matches the OEM headlights and are one of the best ways to easily add styling to your Mustang!
Aggressive appearance. The OEM combination lamps have a chrome appearance that sticks out from the blacked-out headlights. The Elite Series Combination Lamps have a gloss black bezel finish that matches the headlights for a more aggressive appearance on the road.
Unique startup. Not only do these lamps provide an increase in performance, they also feature a unique startup sequence. Anytime you unlock or lock your Mustang, or open the doors, they will turn on in a startup animation. The lamps sweep on before sequencing off, and then gradually ramp-up to full brightness.
Fog upgrade. The fog light optic has been completely redesigned to be larger with a sharper cutoff, wider beam pattern, and 30% more light output than the stock fog.
The fog light is available in a cool white or selective yellow color. The white is a 6000K color temperature, which is a true cool white output, and matches the factory headlights. The selective yellow is a 3000K color temperature, great for high contrast in poor weather or a distinctive look on the road.
Sequencing turn signal. Anytime you hit your turn signal, they light up in a programmable sequential amber pattern, just like the factory tail lights, to indicate signaling. Use the integrated switch to choose between U.S., E.U., and static blink rates to achieve your own custom look!
  • US: Sequential turn signal rate that matches the USDM tail lights
  • EU: Faster sequential turn signal rate
  • Off: Static, non-sequential turn signal
High-power DRL. These combination fog lamps operate as an extra, high-power daytime running light, so you can show them off day or night. The included harness connects to your headlights and enables them to light up with high intensity for visibility even in direct sunlight.
OEM-fitment. At Diode Dynamics, we use a 3D scanner to develop plug-and-play replacement housings that will be a perfect fit. Simply remove the original housings, and ours will fit directly in its place. They also use OEM connectors that plug right into the factory socket.
In the Box:NOTE: These lamps are not compatible with the Shelby GT350, GT350R, and GT500 models.
See how to install our Elite Series Combination Fog Lamp for 2018-2021 Ford Mustang!
Reliable operation. Like most Diode Dynamics products, these Mustang combination fog lamps are designed with newer constant-current circuitry and transient voltage protection. These features, found in factory-installed lighting components, protect the circuit over time, ensuring years of flicker-free performance.
These lamps were designed to last the life of your vehicle, and have been subjected to advanced transient voltage testing. These tests replicate the electrical wear and tear experienced in automotive environments every time your alternator starts and stops, which is what kills less robust electronics over time. They are also tested for long-term operation from -40 to 185 degrees F, vibration, and corrosion. All of these tests are completed to SAE/DOT standards, just like the factory components.
Diode Dynamics Elite Series Combination Fog Lamp for 2018-2021 Ford Mustang are proudly assembled in the U.S.A, and are backed by a 3-year warranty.
If you have any questions, please don't hesitate to post, PM, or email contact@diodedynamics.com.
PM us for the free-shipping code (U.S. forum members only)
Thanks for looking,
John C.
Diode Dynamics
__________________
John C.
Diode Dynamics
Follow Us: FB // IG // YT // TikTok3
Old 8/24/21, 01:47 PM
Supporting Vendor
Our production team is hard at work here at the Diode Dynamics headquarters assembling and testing our Elite Series Sequential Foglight for 2018+ Ford Mustang!
Stay tuned for more updates!
John C.
Diode Dynamics
__________________
John C.
Diode Dynamics
Old 12/10/21, 12:56 PM
Supporting Vendor
Check out this awesome video of our Elite Series Combination Fog Lamp for 2018-2021 Ford Mustang from STEEDA!
Just a reminder, all US forum members are eligible for a free shipping code. Just PM us!
John C.
Diode Dynamics
__________________
John C.
Diode Dynamics
Old 3/25/22, 11:24 AM
Supporting Vendor
Interested in learning more about the installation process?
CJ Pony Parts is an official Diode Dynamics dealer and has provided a great video for everyone!
__________________
John C.
Diode Dynamics
Old 4/21/22, 02:52 PM
Supporting Vendor
Our Elite Series Combination Fog Lamps for 2018-2022 Ford Mustang is NOW in stock!
Just a reminder, all US forum members are eligible for a free shipping code. Just send us a direct message.
__________________
John C.
Diode Dynamics
Old 5/26/22, 10:55 AM
Supporting Vendor
Diode Dynamics’ Memorial Day Sale is going on NOW through Friday, 6/3.
Get 15% off all LED lighting upgrades with code "USA22" during checkout!
Plus, all orders over $300, will receive FREE shipping.
Click HERE to shop Diode Dynamics LED Lighting products!
Note: Products on pre-order (Elite Series Fog Lamps) are excluded from this sale.
__________________
John C.
Diode Dynamics
Old 6/3/22, 03:13 PM
Supporting Vendor
Don't miss your chance to save 15% off your entire order of lighting upgrades!
Coupon Code: USA22
Plus, get FREE shipping when you spend $300! HURRY, this sale ends TONIGHT!
Click HERE to Shop!
Sale ends 11:59 p.m. CST | Friday, 06/3/2022.
Note: Items on pre-order are exempt from the sale.
__________________
John C.
Diode Dynamics
Old 6/30/22, 09:46 AM
Supporting Vendor
Our July 4th Sale starts NOW! Today through Friday, 7/8/2022, save 15% on all LED upgrades by entering coupon code "JULY4" at checkout!
Plus, all orders over $300 will receive free US shipping.
Click HERE to Shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 7/8/2022. Cannot be combined with other coupon codes.
__________________
John C.
Diode Dynamics
Old 7/5/22, 03:03 PM
Supporting Vendor
THE CLOCK IS TICKING!
Hurry! There are ONLY 3 DAYS LEFT to save on your favorite LED lighting products from Diode Dynamics.
Click HERE to shop!
John C.
Diode Dynamics
__________________
John C.
Diode Dynamics
Old 7/27/22, 02:47 PM
Supporting Vendor
Check out the recent video from our friends over at Steeda!
__________________
John C.
Diode Dynamics
Old 9/6/22, 01:17 PM
Supporting Vendor
The clock is ticking!
Click HERE to shop!
John C.
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 9/9/2022. Cannot be combined with other coupon codes.
__________________
John C.
Diode Dynamics
Old 3/6/23, 01:35 PM
Supporting Vendor
Our Tax Refund Sale is LIVE! 🚨 Visit our website to SAVE!
➡ Up to 15% OFF All Lighting Upgrades
➡ 15% OFF Stage Series Rock Lights & HitchMount LED Pods
➡ 10% OFF Elite Series JL/JT Headlights
➡ Free US Shipping on any order over $300!
No coupon code is required.
Click HERE to shop your ride!
John C.
Diode Dynamics
[CENTER]Sale ends 11:59 p.m. CST on Monday, 3/13/2023. Cannot be combined with other coupon codes. Excludes items with pre-order status.
__________________
John C.
Diode Dynamics
Old 3/10/23, 03:08 PM
Supporting Vendor
⌛THE CLOCK IS TICKING... ⌛
NOW
is your chance to SAVE up to 15% sitewide on your favorite Diode Dynamics LED lighting products.
Up to 15% OFF LED Lighting Upgrades
CLICK HERE TO SHOP NOW
Did you know?
You can find all of the products we offer for your vehicle using our vehicle finder tool! Simply enter the year, make, and model.
SALE EXPIRES 11:59 P.M. MONDAY, MARCH 13TH, 2023.
Discounts cannot be combined with other offers or any previous orders. Excludes items with pre-order status.
__________________
John C.
Diode Dynamics
Old 3/23/23, 09:12 AM
Supporting Vendor
Shoutout to Jaron Cole with RTR for rocking our Elite Series Mustang Combination Fog Lamps!
Instagram:
https://www.instagram.com/jcolephoto/
__________________
John C.
Diode Dynamics
Old 5/25/23, 10:56 AM
Supporting Vendor
[MEDIA=youtube]utD2YXqp3Yg[/MEDIA]
🚨 Our Memorial Day Sale is LIVE!!! 🚨
➡ Up to 15% OFF Sitewide
10% OFF JL/JT Elite Series Headlights
➡ Free US Shipping on any orders over $300!
Excluded: F150 Elite Series Headlights, and F150 Elite Series Fog Lights
John C.
Diode Dynamics
Hours: Monday-Friday 10 a.m. - 5 p.m.
Email: contact@diodedynamics.com
Phone: 314-205-3033
Sale ends 11:59 p.m. CST on Friday, 6/2/2023. Cannot be combined with other coupon codes.
__________________
John C.
Diode Dynamics
Old 7/3/23, 01:21 PM
Supporting Vendor
Ignite your lighting game this July 4th!
20% OFF Single Row Stage Series Light Bars
15% OFF Sitewide
10% JL/JT Elite Series Headlights
Plus, score FREE shipping and a FREE Diode Flag Tee with any purchase over $300!
NO COUPON CODE REQUIRED
➡️ https://www.diodedynamics.com/ ⬅️
Expires at 11:59 p.m., Friday, July, 7th, 2023.
__________________
John C.
Diode Dynamics
Old 9/8/23, 02:35 PM
Supporting Vendor
It's your LAST CHANCE!
Save big on your favorite lighting brand with the summer’s LAST sale! From off-road lighting to LED Interior bulbs, we've got your vehicle covered from bumper to bumper.
The sale ends TONIGHT at MIDNIGHT.
Click HERE to shop!
Exclusions apply. While supplies last.
__________________
John C.
Diode Dynamics
Old 2/13/24, 09:59 AM
Supporting Vendor
__________________
John C.
Diode Dynamics
lakeguy77
'10-14 Exterior Modifications
7/1/14 10:52 AM
bones302
6/8/12 06:42 AM
Norm1961
1/20/10 11:22 AM
Quick Reply: It's HERE! Elite Series Sequential Foglight for 2018+ Ford Mustang | Diode Dynamics
