GT500 Fog Light LED Bulbs! Plug & Play install! For All Years! Matches Factory DRLs!
Supporting Vendor
We carry LED bulbs for replacement of your GT500's fog lights or DRLs, in all major sizes. This will make your fog lights a nice bright white, without the hassle of HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
We also offer three options in brightness:
HP48: 265 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
XP80: 510 lumens. Similar brightness to factory.
XML2:1420 lumens. Much brighter than factory. These are bright! Available in Natural White (4300K) / Pure White (5000K) / Cool White (6000K)
*XML2 is available in 3000K (yellow) / 4000K / 5000K / 6000K
Bulb Design:
HP48: This bulb is designed with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your GT500).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2007-2014 GT500 Fog Light LEDs
2007-2014 GT500 RGB Fog Light LEDs
***We have bulbs for all GT500 Model Years!!!***
Any questions, feel free to ask via email (contact@diodedynamics.com), Post, PM or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks,
Nick C.
Diode Dynamics
Customer Review:
"Bought the stage 3 white for my 11 GT. Matches real nice with my 6k HID and installed in literally 5 minutes. Awesome addition to my car, def adds to the front end" (Posted on January 9, 2014)
The following 2 users liked this post by Diode Dynamics:
ofequipmentgolf (11/8/16),
rpoppertdomi (10/25/16)
Supporting Vendor
