Vendor Showcase Forum for Vendors to display their products and specials
2013-2014 Mustang RGBW Multicolor LED Board Replacements! Factory DRL Upgrade!
Old Oct 5, 2015 | 01:11 PM
Diode Dynamics's Avatar
Former Vendor
Arrow 2013-2014 Mustang RGBW Multicolor LED Board Replacements! Factory DRL Upgrade!
2013-2014 Ford Mustang DRL LED Boards
Upgrade your Mustang's factory DRLs with these drop-in RGBW multicolor replacement LEDs! These modules are a direct replacement for the factory-installed LED panels in the 2013-2014 Ford Mustang. Your order includes a full set of panels, as well as drivers to safely and reliably power them.
From the factory, the DRLs in the headlight are illuminated by small 1210-size white LEDs. Our multicolor board is designed with high-power RGBW LEDs, as a drop-in replacement. You don't have to align and fasten LEDs- this is an OEM-grade solution. Just remove the old panel, and ours fits directly in place, with patent-pending fit and finish.
Made in USA, the replacement panels utilize RGBW LED chips. Each one illuminates with red, blue, green, and 6500K white. The multicolor function allows for full multicolor control using any standard common-anode RGB or RGBW controller (not included).
Remember, this product is not just RGB- it is RGBW! That means there is an LED chip that is specifically white in color, right next to the standard red, green, and blue chips. By using an RGBW controller rather than the standard RGB, you can activate and control the white chip independently of the colors. This provides a much more uniform, pure, and bright white color than the traditional method of combining all RGB signals.
To drive the LEDs safely, a new constant-current driver is included for each set, for high reliability. You will also need a standard RGB or RGBW controller. Controllers can usually be powered by any standard 12V source. We recommend connecting to the parking light signal, so this module lights up when the parking lights or headlights are on, or to the factory power input signal.
There is a standard RGBW input plug (5-pin) to connect to your RGBW controller. This connector is plug-and-play with Diode Dynamics controllers. We strongly recommend the use of Diode Dynamics controllers with this product, for ease-of-use. However, you can connect any standard RGB or RGBW controller by cutting the pins off the connector end, and connecting them to your controller, in the required color configuration, as dictated by the controller you use. This does not void the warranty.
Professional installation is strongly recommended, as the factory headlights must be opened in order to replace the LED panels.
All Diode Dynamics products are backed by a 3-year replacement warranty.
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Old Oct 7, 2015 | 09:42 AM
Former Vendor
Old Oct 9, 2015 | 06:57 AM
Former Vendor
Old Oct 15, 2015 | 08:15 AM
Former Vendor
Old Jan 28, 2016 | 07:15 AM
Former Vendor
Customer Submitted Photo
These LED Board replacements fit all 2013-2014 Mustang models
Nick C.
Old Mar 25, 2016 | 07:48 AM
Former Vendor
2013-2014 Mustang RGBW Multicolor LED Board Replacements! Factory DRL Upgrade!-img_9233.jpg
Old Mar 25, 2016 | 09:22 AM
Jazzman442's Avatar
What other controllers work with these?
Can you get a Black Controller?
Old Mar 25, 2016 | 09:29 AM
Former Vendor
Any of our RGB controllers will be compatible, but you'll lose the benefit of the added white unless you are using an RGBW controller.
Nick C.
Old Apr 13, 2016 | 02:42 PM
Jazzman442's Avatar
I want to order these. Is it true it will take 6 to 8 weeks?
Any sooner?
Do you make a smaller black controller? or just Black?
Old Apr 13, 2016 | 02:47 PM
Former Vendor
Please contact us for more information: (314) 205-3033
Thank you!
Nick C.
Old May 25, 2016 | 03:23 PM
Former Vendor
Customer Submitted Photo - Notorious Photography: https://www.facebook.com/TheNotoriou...raphy/timeline
Nick C.
Old May 26, 2016 | 07:59 AM
Former Vendor
Nick C.
Old May 27, 2016 | 07:52 AM
Former Vendor
Nick C.
Old Aug 16, 2016 | 03:03 PM
Former Vendor
Nick C.
Old Aug 17, 2016 | 11:04 PM
renee29581's Avatar
I want this but I also don't want the cops pulling me over lol
Old Aug 18, 2016 | 07:20 AM
Former Vendor
Luckily they have a built-in white so you can stay perfectly road legal while driving!
(RGBW = Multicolor + White)
Thanks!
Nick C.
Old Aug 18, 2016 | 08:47 AM
renee29581's Avatar
Thanks!
Nick C.
Yea but not to sure I want to keep it in white for 120 bucks either lol
Old Aug 18, 2016 | 08:51 AM
Former Vendor
With the RGBW boards, you'll have the best of both worlds. You can decide which color you'd like to run at any time and still be able to switch to white.
Nick C.
Old Aug 18, 2016 | 10:24 AM
renee29581's Avatar
Nick C.
Maybe if I can get them for 60 bucks I'll get them..until then 120 is too high!!!
Old Aug 18, 2016 | 10:26 AM
Former Vendor
It's a very reasonable price when you consider how much work our engineering team put into the design and development of this product. Also, the cost of production employees we pay here in St. Louis vs. having them produced overseas.
Nick C.
