Sponsored by:
Sponsored by: CARiD
Steeda S550 Mustang Extreme G-Trac Brace
Old Jan 8, 2015 | 08:12 PM
tj@steeda's Avatar
Steeda is proud to announce that we have just released our Extreme G-Trac Brace! This is a wonderful addition for any 2015 owner.
Our Extreme G-Trac Brace is a direct bolt-on and provides greatly improved front chassis bracing. This brace mounts close to the control arm mounts, and helps strengthen the connection between the control arm mounts and the rear of the sub-frame. This makes the load path more direct and gives much more effective stiffening, so the suspension geometry doesn't change during high cornering/chassis loads.
The Steeda Extreme G-Trac Brace is manufactured from super strong chrome moly, alloy steel tubing, making it over twice as strong as any mild steel offering. All necessary installation hardware is included and this is a direct bolt-on upgrade which provides improved suspension compliance while stiffening the sub-frame.
Key features are as follows:
-Mounts close to the control arm mounts
-Helps strengthen the connection between the control arm mounts
-Helps strengthen the rear of the sub frame
-Direct bolt-in item
-Manufactured from super strong chrome moly, alloy steel tubing
http://www.steeda.com/steeda-s550-mu...2015-555-5532/
Let me know if I can help assist you with one! You can email me at tim@steeda.com
Best Regards,
TJ
Old Jan 8, 2015 | 08:48 PM
3point7's Avatar
That's awesome TJ. Now about that wheel hop? Steeda got plans or what?
ustabawannab
Aug 5, 2015 08:32 PM
MADSCOTSMAN
Jul 22, 2015 04:57 PM
MRGTX
Jul 21, 2015 02:08 PM
Jul 21, 2015 10:32 AM
Jul 17, 2015 05:40 PM
