Sponsored by:
Sponsored by: CARiD
Steeda New Part Release - Billet Rear Shock Mount
Old Jul 28, 2016 | 07:59 PM
tj@steeda's Avatar
You asked, and we listened!
Once the aftermarket shocks started coming out for the S550 Mustang, people all across the country ran into issues breaking the factory rear shock mount. Whether it was drag racing or road racing with very stiff shocks, customers were having all sorts of issues. That’s when the team at Steeda got together to come up with a solution.
Made from billet 6061 aluminum, these mounts are designed to replace the weak cast factory units. Unlike the factory mounts that have a rubber bushing that binds and will deteriorate over time on lowered cars or cars with aggressive shock settings, these units feature a Steeda spec stainless steel spherical Teflon lined bearing for optimum performance and control. Steeda also went a step further by making 2 kits, one for factory and Ford Racing shocks that are 10mm in diameter (555-8151) and one for aftermarket shocks like our Pro-Action that are 12mm in diameter (555-8152).
Steeda S550 Mustang Billet Rear Shock Mount - 10mm Rear Shocks (15-17 All) | 555-8151 | $199.95
Steeda S550 Mustang Billet Rear Shock Mount - 12mm Rear Shocks (15-17 All) | 555-8152 | $219.95
Steeda S550 Mustang 12mm Spacer Kit for Billet Rear Shock Mounts (15-17 All) | 555-8153 | $49.95
If you are running stock shocks now but might upgrade to Pro-Actions in the future, no problem, there is no drilling required like the OEM mounts, these mounts are up-gradable with a simple spacer and nut change (555-8153). The Steeda Billet Shock Mounts are a great upgrade to drag racers and road racers alike, or if you’re running aggressive shocks on your car, these will greatly help with control with un-compromised durability.
Now available!
Note: All OEM S550 rear shocks, regardless of package, are 10mm (555-8151), including the aftermarket Ford Racing performance units. Aftermarket shocks like Steeda ProAction, Koni and Bilstein are 12mm units (555-8152). Upgrade kits are available if you change shocks later down the road from 10mm-12mm (555-8153).
Best Regards,
TJ
Feb 16, 2016 09:57 AM
TMSBrad
Mar 7, 2004 10:11 PM
TMSBrad
Announcements
Feb 24, 2004 09:34 AM
TMSBrad
Europe
Feb 18, 2004 07:12 AM
