Sponsored by:
Sponsored by: CARiD
Shaker Pro
Old Nov 22, 2014 | 07:36 PM
smike308's Avatar
Shaker Pro
Does the Shaker Pro radio system have the 10 gb hard drive, like the S197 Electronics package did?
Old Nov 22, 2014 | 08:22 PM
MustangJoe84's Avatar
If you are referring to the CD Jukebox feature where you can record and store CD's for playback, then no, it does not. The new Mustang uses the current MyFordTouch SD card technology for storing the navigation locations. In the previous system the excess space left over from the navigation hard drive allowed for the storing of music.
Old Nov 22, 2014 | 08:33 PM
smike308's Avatar
MustangJoe84--thank You for that info. I'm not real tech savvy. Does that mean you can store music on an SD card and plug it in to the radio?
Old Nov 22, 2014 | 08:45 PM
smike308's Avatar
Deleted--double post
Old Nov 22, 2014 | 09:31 PM
Yes, you can listen to music stored on an SD card. You can also listen to music stored on a thumb drive or IPod device using the USB slots with the system. Any device that you plug in will also be 'indexed' by the system and allows you to use a voice command to find a particular song or artist. You can even save a photo stored from a plugged in SD or USB device as a background for the MyFordTouch 8" screen.
Old Nov 22, 2014 | 09:58 PM
smike308's Avatar
MustangJoe84--thanks again.
Old Nov 24, 2014 | 12:47 PM
AWmustang's Avatar
You can buy your own SD card and load music on it, but you must do that on your computer. You can't do that through the car.
Also, if you have the Nav, you can't use that SD card to store music. If you remove that SD card to put your music one in, you won't have access to the navigation system.
I just bought a Thumb drive for a couple bucks and loaded my music on there so I didn't have to worry about not having access to the navigation. If you don't have navigation, then it doesn't matter whether you use the SD card or a thumbdrive in the USB.
Old Nov 24, 2014 | 03:28 PM
smike308's Avatar
AWmustang--Thanks for the additional info. I think I like the old system better the more I hear about the new one.
duppycat
Feb 16, 2019 08:36 AM
TripleBlack14
Sep 17, 2015 07:48 AM
scott6809
Sep 12, 2015 11:44 PM
